    Can peltier can be connected to PWM fan pins ?
    • allankisaiswaroopundefined
      allankisaiswaroop
      Hi to all,
      Can peltier can be connected to PWM fan pins ? Please help in this.
        The fan PWM pins are limited to 1.5A max continuous current. Most peltier units draw more current than that.
          allankisaiswaroop
          Hi dc42,
          Thanks for reply. Is there any alternative for that like using any electronic components?
            You could use an SSR or mosfet switch to switch the current to the Peltier device, and connect the inputs of the SSR or mosfet switch to a fan output.
              allankisaiswaroop
              can you get a circuit design for the same? or can you tell which mosfet i have to use?
