12V on duetwifi + duex5
Hi all,
I am about to pair my duex5 with my duet wifi and bring my input voltage to 24V.
I can't find a good picture of the intended mechanical mounting of the 2 PCBs, is it simply back to back with standoffs? can people who went this route show me picture of their installation for inspiration please?
I would like to get the 12V from the embedded duex5 power supply for my general 12V needs (I guess it's mostly fans) I can't seem to find a breakout pin to bring it back to the big duet wifi, did I miss something on the schematics?
thanks all for your help.
The intended mounting is either back to back using standoffs, or side-by-side with the VIN terminal blocks next to each other.
Current DueX5 boards don't have a 12V output pin, however if you set the fan voltage selector jumper to 12V then you can pick up 12V from any of the fan ouputs connectors on the DueX.
@nraynaud said in 12V on duetwifi + duex5:
Hi all,
Does this help I have used 20mm nylon M3 standoffs
Thanks you all.
dc42> may I suggest you break out the 12V with an actual 2A capable connector for the next revision? This is a really compelling power rail.
Thanks you all.
Already done!
