    Crazy moves
    • jarjarundefined
      jarjar
      On my delta, with a 300mm round bed, I'm trying to print a priming line before starting the actual print with the following gcode:
      G90 ; absolute positioning
      G0 X-49 Y-139 Z0.2 F12000
      ; Arc Prime Line
      G3 X10 Y-147 I49 J139 E9 F1000
      G3 X49 Y-139 I-10 J147 E12.5 F1000
      When I input this gcode manually in the web console, it works fine.
      When trying to print a file, the first G3 move makes the printer go up diagonally?!
      For reference, this is the whole gcode header in the test print file:
      ; generated by Slic3r 1.37.2-prusa3d on 2018-06-15 at 20:50:46
      ; external perimeters extrusion width = 0.45mm
      ; perimeters extrusion width = 0.45mm
      ; infill extrusion width = 0.50mm
      ; solid infill extrusion width = 0.45mm
      ; top infill extrusion width = 0.40mm
      ; first layer extrusion width = 0.42mm
      M107
      M83 ; extruder relative mode
      M104 S160 ; warm extruder to calib. temp
      M140 S75 ; set bed temp
      M190 S75 ; wait for bed temp
      M109 R160 ; wait for extruder temp
      G32 ; auto calibrate
      G1 X-49 Y-139 Z0.2 F12000 ; go to ooze position
      M109 S215 ; wait for extruder temp
      ; Arc Prime Line
      G3 X49 Y-139 I-10 J147 E10 F1000
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M83 ; use relative distances for extrusion
      ;BEFORE_LAYER_CHANGE
      ;0.2
        Which firmware version are you using? There were some fixes to G2 and G3 moves recently.
        • jarjarundefined
          jarjar
          I'm using 1.19.2.
          I didn't bother upgrading since I did not see any bug fixes related to G3 moves in the recent releases.
          • jarjarundefined
            jarjar
            I updated to 1.21, and saw a message that the G3 was outside limits.
            After updating the printable radius all is good. Sorry for the noise.
