6-Sphere vs 3-Sphere Effector & Duet Geometry
When it comes to delta printers with magnetic rods , does the Duet firmware (or the firmware it uses as its basis) presupposes a 6-Sphere effector geometry?
I'm asking this because I'm wondering whether the use of a 3-sphere effector (like the one used, for example, by SpiderBot) might negatively impact the possibility of getting a good overall calibration of the printer.
To better explain my thoughts on this, here's one example:
Connecting the 6 magnetic rods to a 3-sphere effector generates a different angle between the rods and the effector than the angle created by connecting the same rods to a 6-sphere effector.
This different angle, in turn, means the 'delta radius' is also different in the 2 cases, and since this is a fundamental parameter in the machine's calibration, I'm worried that a presupposition about a 6-sphere effector in the firmware would lead to calibration difficulties when using a 3-sphere effector.
Or perhaps the difference is so negligible that it wouldn't be noticed?
The firmware doesn't care whether you have 3 spheres or 6, as long as the rods are parallel.
Awesome! Thanks @dc42!
