    Zesty Nimble with Smart Effector mount
    Smart effector for delta printers
    1.6k
    • Chipsa82undefined
      Chipsa82
      Hi!
      Im working on a large-ish delta (400 diameter, 600 Zmax) and Im planning to use the smart effector with the Nimble. I'm thinking of the best way of mounting the extruder stepper and routing the drive cable in a way that would minimize side loads on the effector. Nimble owners - whats your recommended way of mounting the stepper? thanks!
      • bartolomeusundefined
        bartolomeus
        https://www.thingiverse.com/thing:2800798
        • Chipsa82undefined
          Chipsa82
          thanks. are you using this mount? did you see improved performance vs the fixed mount?
            bartolomeus
            I am using it on my delta, but I used it from the start so can't tell if there is a difference.
              A Former User
              I use this mount on my delta
              fixed mount
              Does what it is supposed to, just works
              • Chipsa82undefined
                Chipsa82
                Yeah, the effector mount is kinda sorted, I had the stepper mount in mind. Since I find the drive cable quite tough, Im worried that if I mount the stepper on the Z tower and route the drive cable in a arch to the printhead, the side loads will lead to flexing/movement of the PCB as described in another thread in this forum. I was also thinking of routing the drive cable straight down from the top, but that only works well when printing close to the bed=the drive cable is pretty much straight. the higher the printhead, then the drive cable has to bend, again leading to unwanted pressure on the printhead 🙂
                  A Former User @Chipsa82
                  @chipsa82 said in Zesty Nimble with Smart Effector mount:
                  I have mine mounted on one of the top rails going straight down, agreed there is the possibility of flex/tilt of the effector the higher up you get, but i haven't found that to be an issue because the drive cable is flexible enough.
                  • Chipsa82undefined
                    Chipsa82
                    @CaLviNx great to hear that, do you have a pic of your setup? thanks 😉
                      erm no not on me so to speak, because im on rotation at work in Saudi and the printer is at home for the next 5 weeks until i am back home again sorry.
