    New firmware 2.01 beta 2 available
    Firmware installation
    16
    39
    5.4k
      dc42 administrators @Catalin_RO
      @catalin_ro, thanks for confirming the fix.
      • incogizmoundefined
        incogizmo @dc42
        @dc42 said in New firmware 2.01 beta 2 available:
        • On the Duet 2 Maestro, the 2 optional add-on drivers are now assumed to be TMC2224 with UART interface
        Amazing! I will have some time on the weekend to properly test this! Along with the 7th Driver pin reversal. I will report back as soon as I can.
        incogizmoundefined 1 Reply Last reply Reply Quote 0
        • kraegarundefined
          kraegar
          Tested on my railcore 2 (with a bltouch), a few test prints through, and everything's working as expected.
          • wilrikerundefined
            wilriker @dc42
            • If M28/M29 was used in a macro file to then the commands between M28 and M29 were executed as well as being written to the target file
            The part with executing as well as writing seems to be fixed but still not working as expected. M29 does not seem to be recognized inside a macro. Or not executed.
            I have the following filament load macro:
            M28 /sys/current_material.g
            M98 P/macros/Settings/PETG/DevilDesign
            M29
            • ✔ It will now successfully create the file /sys/current_material.g reliably
            • ✔ It will not exectute /macros/Settings/PETG/DevilDesign (this file exists)
            • ⛔ It will not close the file at the end of the macro but continue to write all following commands into this file until I explicitely call M29 via GCode console - strangely enough the M29 from the macro will also not end up in the written file
            So, if I execute the above macro by loading the filament this is assigned to and afterwards enter the following commands manually in GCode Console
            1. M82
            2. M84
            3. M29
            I end up with the following contents in /sys/current_material.g
            M82
            M84
            If I enter M29 immediately after loading the filament it will only be the first line.
            EDIT: On GCode console I get the following output (note: descending time stamp)
            16:27:04    M29
                        Done saving file.
            16:26:54    M702
                        M701 S"PETG_DevilDesign"
                        Writing to file: /sys/current_material.g
                        GCode end-of-file being interpreted.
            Manuel
            My Tool Collection
            • OBELIKSundefined
              OBELIKS
              Would it be possible to get a mirror for the files? github seems to have problems.
              P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
              Original Prusa i3 MK3S
              OBELIKSundefined 1 Reply Last reply Reply Quote 0
              • keyz182undefined
                keyz182 @dc42
                @dc42 laser engraving working great here too. With the G1 S for lasers you said would be in 2.02 (I think) things should be perfect!
                • OBELIKSundefined
                  OBELIKS @OBELIKS
                  @obeliks nevermind, it's back
                    dc42 administrators @wilriker
                    @wilriker said in New firmware 2.01 beta 2 available:
                    M29
                    1. M82
                    2. M84
                    3. M29
                    M82
                    M84
                    16:27:04    M29
                                Done saving file.
                    16:26:54    M702
                    Strange, I tested it several times and it worked for me. Please try adding a comment line in your macro file after the M29 command, in case the M29 at the end of the file isn't being interpreted correctly..
                    • wilrikerundefined
                      wilriker @dc42
                      Adding an additional line with just a comment at the end makes it work. Adding an inline comment on the M29 line does not change the faulty behavior.
                      Now, why would the last line not be interpreted correctly? These seems only to apply to M29. I just tested with a M117 as the last line (right after M29) and the text was displayed.
                      Manuel
                      My Tool Collection
                      • BPisLifeundefined
                        BPisLife
                        Using this version on 4 different printers with no noticable differences between beta 1 and 2. BLtouch has been working much better over these past two versions. Thanks for taking the time to make them work perfectly (ie no-bounce, fast response).
                          Before you added the comment, did you have a newline at the end of the M29, or not?
                            dc42 administrators @BPisLife
                            @bpislife said in New firmware 2.01 beta 2 available:
                            Thanks for the feedback!
                            • wilrikerundefined
                              wilriker @dc42
                              I did not. Is that an implicit requirement?
                              EDIT: Empty newline at the end also works.
                              Manuel
                              My Tool Collection
                                Thanks for confirming that. The firmware appends a newline to the end of the last command if there isn't one, but I guess it's doing it a little too late in the case of having to recognise M29. I'll fix it in the next beta or RC if the fix isn't complicated.
                                  incogizmo @incogizmo
                                  @incogizmo said in New firmware 2.01 beta 2 available:
                                  @dc42 got to testing it all sooner than expected. Can confirm microstepping is now applying on both addon drivers and driver 6 (7th driver) is also working as expected.
                                  Are there any commands or anything else I can do to help you confirm all is working as expected?
                                    dc42 administrators @incogizmo
                                    Thanks for confirming this. I can't think of any other tests needed on the expansion board at present.
                                      I just had a print stop on me. I think it happened when I tried to connect to the DWC from my iphone to check on the print. I had just looked at the camera and things we're going smoothly. I loaded the DWC and it wouldn't finish loading on the iphone. I went to check the printer and it was stopped sitting above the print. Heaters off and cooling down.
                                      M122
                                      M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet WiFi 1.02 or later
                                      Board ID: 08DDM-9FAM2-LW4SD-6JKF0-3SN6N-T2ZBY
                                      Used output buffers: 3 of 20 (10 max)
                                      Static ram: 28484
                                      Dynamic ram: 96160 of which 0 recycled
                                      Exception stack ram used: 328
                                      Never used ram: 6100
                                      Tasks: NETWORK(ready,328) HEAT(blocked,1192) MAIN(running,3616)
                                      Owned mutexes:
                                      Last reset 00:16:07 ago, cause: software
                                      Last software reset at 2018-07-20 22:02, reason: Stuck in spin loop, spinning module PrintMonitor, available RAM 5724 bytes (slot 1)
                                      Software reset code 0x4049 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2001ffd0 Task 0x4e49414d
                                      Stack: 00000008 0044509b 00008096 ffffffed 00000000 00f00000 e000ef34 c0000000 20006c94 00445195 00444f0c 61000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
                                      Error status: 0
                                      Free file entries: 10
                                      MCU temperature: min 36.6, current 38.8, max 40.1
                                      Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
                                      Date/time: 2018-07-20 22:19:11
                                      Slowest loop: 9.67ms; fastest: 0.08ms
                                      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                                      Bed compensation in use: mesh
                                      Heater 1 is on, I-accum = 0.0
                                      Segments left: 0
                                      Movement lock held by null
                                      http is idle in state(s) 0
                                      telnet is idle in state(s) 0
                                      file is idle in state(s) 0
                                      serial is idle in state(s) 0
                                      aux is idle in state(s) 0
                                      daemon is idle in state(s) 0
                                      queue is idle in state(s) 0
                                      Code queue is empty.
                                      === Network ===
                                      Slowest loop: 71.55ms; fastest: 0.01ms
                                      HTTP sessions: 1 of 8
                                      - WiFi -
                                      Network state is running
                                      WiFi firmware version 1.21
                                      WiFi MAC address 5c:cf:7f:ef:4a:74
                                      WiFi Vcc 3.31, reset reason Turned on by main processor
                                      WiFi flash size 4194304, free heap 14808
                                      WiFi IP address 10.10.0.63
                                      WiFi signal strength -36dBm, reconnections 0, sleep mode modem
                                      === Expansion ===
                                      In the console of the PanelDue I also see an error from 3 hours earlier saying Wifi reported error: incomplete write. But nothing else. I'm not sure what that would have been from.
                                      • DocTruckerundefined
                                        DocTrucker
                                        I'm running an earlier version of post 2.0 beta firmware (will confirm on Monday) on a Duet Ethernet/Deux5/CoreXY with three steppers for the z-axis.
                                        I run a bed level compensation that probes three points in the bed.g file and adjusts the screws to level the bed.
                                        I've a limit switch on max y (homing works fine) but found that if the coordinate in the bed.g is beyond that limit switch the system will drive the axis into the switch and then some while the stepper misses steps.
                                          dc42 administrators @Phaedrux
                                          @phaedrux said in New firmware 2.01 beta 2 available:
                                          Thanks for your report. Unfortunately the stack trace doesn't provide any useful data in this case. I will change it in the next beta.
                                            dc42 administrators @DocTrucker
                                            @doctrucker said in New firmware 2.01 beta 2 available:
                                            The coordinates of points in bed.g files are not checked against the axis limits. This is because on delta printers it is sometimes useful to probe beyond the normal bed limits.
