DuetWiFi external enclosure?
Thanks for the quick response dc42.
I wish I could use your design but I know nothing about editing your scad file to remove the mains portion of the panel and I'm not able to print something that is 280mm long. I'm in no rush to use the new DuetWiFi and will simply wait until a usable enclosure is designed and shared by others. -
This is my case design that can have a fan adaptor bolted on for forced air cooling.
Main case in orange, fan holder in green.
If your interested I can share but need to extend the internal height a little for cabling clearance and add some mounting feet to the baseLooking at it I could also add some internal thru base mount holes, open to ideas
Thanks very much Aussiephil,
Your design looks like it will work for me in its present state. I'll be watching for when you have it completed. -
OK changes from my printed version are an extra 20mm of internal height, larger cable exit holes and four mounting holes located internally but outside the pcb edges so it can be mounted after the board is wired.
lid mount holes are set for 20mm x m3 screws, think 16mm may be ok
case is 149mm x 128mm so should fit most print beds, the base and the lid are printed independently.
Render from Fusion 360 as i haven't printed this
Files can be found downloaded from here -
https://dl.dropboxusercontent.com/u/28032744/HexDelta/casebottom.stl
https://dl.dropboxusercontent.com/u/28032744/HexDelta/caselid.stlI'll publish to thingiverse after you or I print a copy
Cheers
Wow this design looks very nice and well thought out. I will print one first thing in the am and report back. Good luck with your big printer, I hope that you get it back up soon.
Phil
Could you also post the STL for your Fan Duct for it please?
Doug
Phil
Doug
the fan duct i have available is for a 75x75x30 radial blowerโฆ. if your have a different size fan i can fairly quickly change it as most of the design for the duct is parametric.
you need 2 x 20mm M4 bolts and 2 x M4 normal nuts
Here is the plate for a 75x75x30 Radial blower
Fusion 360 Render
STL File: https://dl.dropboxusercontent.com/u/28032744/HexDelta/adapter%20plate%2075x75x30%20blower.stl
I have a few low speed (quiet ones of these lying around otherwise a low speed 50mm would be more than enough.
If anyone wants to design their own the key numbers are
Mount hole centres 62mm
Mount hole size 4.2mm (M4)
Hole centre from bottom: 7mm
Slot opening: 12mm x 50mmCheers
Phil. Just thought I'd let you know that I've stolen copies of your files as well. Many thanks.
Phil,
Both parts printed as expected, Each took a little over 5 hours, and it makes a very nice enclosure. Better than I was expecting. Even though it is nice to know that the DuetWiFi does not need active cooling, the fan and airflow design is simply brilliant. Thanks very much! If you share it on Thingiverse I will post a make for it. -
Phil,
Both parts printed as expected, Each took a little over 5 hours, and it makes a very nice enclosure. Better than I was expecting. Even though it is nice to know that the DuetWiFi does not need active cooling, the fan and airflow design is simply brilliant. Thanks very much! If you share it on Thingiverse I will post a make for it.Thanks for the kind words and trusting the print would work
I've now published it over on thingiverse
http://www.thingiverse.com/thing:1694608I'll look at doing a 50mm and 40mm radial fan adapters soon.
I would expect that with the wifi end mounted upwards in a vertical fashion that the natural convectional cooling may well be good enough for most people as it should flow quite well.
Cheers
Phil -
New Case lid file uploaded both to dropbox and to thingiverse.Found the mount holes had shifted when i extended the internal height, apologies for any inconvenience.
Found this when I went to print my own copy
Cheers
Phil
