    Problem getting a laser to work
    Laser Cutters
    2.3k
      @appjaws said in Problem getting a laser to work:
      M307 H3 A-1 C-1 D-1 ; Disable Heater output on H3
      M452 H3 R255 F200 : Enable Laser mode on output 3 (heater 3) max intensity 255 PWM frequency 200
      M571 P3 F200 S255
      M563 P0 D0 H3 ; Define tool 0 uses heater 3
      The first 2 lines look OK to me if the laser is driven from the heater 3 output. The M571 and M563 lines should be removed.
      M452 P0 R255 F200 : Enable Laser mode on fan0 max intensity 255 PWM frequency 200
      M571 P0 F200 S255 ; Set output on extrude
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      P0 means the heater 0 pin, not fan 0.
      appjawsundefined 1 Reply Last reply Reply Quote 0
      • appjawsundefined
        appjaws @dc42
        Thanks dc42
        Is the following all I need to define that the laser should work PWM from Fan0?
        M106 P0 S0 I0 F500 H-1 Is the only reference to
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
          No, you need I-1 in the M106 command to disable the fan and make the pin available as a general purpose output pin. And of course P20 in the M452 command.
          • appjawsundefined
            appjaws
            Well I made the changes as suggested and am getting the following errors:-
            Error: M106: Fan 0 is disabled
            Error: Attempting to extrude with no tool selected.
            This is the config:-
            M555 P2 ; Set output to look like Marlin
            G21 ; Work in millimetres
            G90 ; Send absolute corrdinates...
            M574 X1 Y2 S1 ; set endstop configuration (Y endstop only, at high end, active high)
            M92 X87.4890 Y87.4890 Z4000 ; Set axis steps/mm
            M906 X950 Y950 Z950 ; Set motor currents (mA)
            M201 X500 Y500 Z15 ; set accelerations
            M203 X9000 Y9000 Z100 ; set maximum XYZ speeds
            M566 X300 Y300 Z30 ; Maximum instantaneous speed changes mm/minute
            M208 X200 Y200 Z190 ; set axis maxima
            M208 X0 Y0 Z0 S1 ; set axis minimum (adjust to make X=0 the edge of the bed)
            M452 P20 R255 F200 : Enable Laser mode on fan0 max intensity 255 PWM frequency 200
            M106 P0 S0 I-1 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M92 E430 ; Set extruder steps per mm
            M558 P0 ; No Z probe installed
            M302 P1 ; disable the "do not extrude when cold" function
            G92 Z0 ;fake Z homed
            M564 S0 ; allow Z below Z=0
            T0 : select tool 0
            What am I doing wrong?
            Simplify3D 5.1.2
              If you have laser mode selected using M452 then you should not be trying to extrude. Laser mode uses M3 to set the laser power.
              Is this an existing system that was using M571 to control a laser and you just want to upgrade the firmware, or is this the first time you have connected a laser to a Duet?
              • appjawsundefined
                appjaws
                Thank you so much, I now understand and can report that using M3 to control the laser works.
                I knew it was my lack of understanding.
                This is a new installation of a laser onto my ormerod using Duet 6
                Simplify3D 5.1.2
                • appjawsundefined
                  appjaws
                  I have something very strange.
                  M3 S255 turns the laser OFF as does M3 S0
                  It appears that the maximum power is around M3 S127
                  Simplify3D 5.1.2
                  keyz182undefined 1 Reply Last reply Reply Quote 0
                  • keyz182undefined
                    keyz182 @appjaws
                    Try lowering or increasing the PWM frequency with the M452 F parameter. Some of the laser module controllers are a bit picky. You can also use the R parameter of M452 to set the PWM level that corresponds to max, so in your case, R127.
                    • appjawsundefined
                      appjaws
                      I tried changing the frequency but could not see any improvement.
                      I am currently using M3 S107 as my maximum power.
                      It works but I would prefer to have 255 levels of power, especially engraving photos.
                      Any other ideas as to how I can use the full range?
                      Simplify3D 5.1.2
                      • resamundefined
                        resam
                        @appjaws which laser and laser control board did you buy?
                        Most of them use a "simple" PWM signal between 0-5V to control the laser intensity.
                        I doubt that your laser really has a 50%-ish PWM signal as "full power" signal...
                        • appjawsundefined
                          appjaws
                          I've just measured the voltage on the Fan0 pin and it is fluctuating between 5.5V - 10.7V.
                          Do you think I am over driving the PWM input?
                          The problem I had no information supplied with the 2000mw laser and control board that I bought.
                          I have tried to find out the correct voltage but was unsuccessful.
                          This is a picture of the laser I bought
                          Simplify3D 5.1.2
                          • keyz182undefined
                            keyz182 @appjaws
                            The ones I've seen have all been 5v PWM controlled, so maybe you're over-driving? Do you have a link to where you bought it? And/Or some high res images of the top+bottom of the PCB?
                            • appjawsundefined
                              appjaws
                              I bought it on ebay and the supplier has no information.
                              I could take some photos of the board but I will need to dismantle my setup first.
                              I wonder what size of resistor I could connect in series to reduce the actual voltage reaching the control board
                              Simplify3D 5.1.2
                              • resamundefined
                                resam
                                Me, and others here on the forum use the HEATER_3 pin with a few extra components, instead of the fan output. Somebody even made a custom PCB for it.
                                https://duet3d.dozuki.com/Wiki/Laser_PWM_control
                                • appjawsundefined
                                  appjaws
                                  I did start with that plan but could not get my lashup to work. I now have a better understanding so perhaps I'll try heater 3 again.
                                  Thanks for your help.
                                  Simplify3D 5.1.2
                                  • appjawsundefined
                                    appjaws
                                    I still haven't got the heater 3 solution as explained in the article "Controlling a PWM Laser with the Duet Board" The diagram indicates that the expansion header pin 8 is heater 3 but I have a constant 3.29 volts between that and pin 2 which is grd.
                                    So I am wondering if the old version 6 boards, which I am using, have the same pin assignments as the version 2 boards.
                                    So I have reverted to using the fan connector with the output reversed and a pull-up 1K resistor connected to +5V.
                                    This is the results of checking the voltage at different S values.
                                    Svalue Voltage Laser
                                    0 4.4
                                    10 2.58
                                    11 2.47
                                    13 2.33 ON
                                    15 2.27
                                    20 2.19
                                    40 2.05
                                    60 1.97
                                    80 1.88
                                    100 1.77
                                    120 1.64
                                    140 1.51
                                    160 1.39
                                    180 1.27
                                    200 1.14
                                    220 1.08
                                    240 0.87
                                    250 0.78
                                    252 0.77
                                    254 0.75
                                    255 0.74 OFF
                                    The increasing S values at the top end result in the power of the laser reducing.
                                    Clearly I have something wrong but I am at a loss as to what to do next.
                                    Simplify3D 5.1.2
                                    • keyz182undefined
                                      keyz182 @appjaws
                                      By this, do you mean this board? - https://reprap.org/wiki/Duet_Wiring#Duet_0.6
                                      • appjawsundefined
                                        appjaws
                                        yes that is the original board on my ormerod
                                        Simplify3D 5.1.2
                                        • keyz182undefined
                                          keyz182 @appjaws
                                          In that case, yes, the pinouts are different. I'm not sure if the circuit will need modification or not on there either.
                                            dc42 administrators @keyz182
                                            Heater 3 will be on a different pin of the expansion connector, but otherwise the same arrangement should work.
