    Configurator BLTouch bug
    3.7k
    • BPisLifeundefined
      BPisLife @RafB
      @rafb do you have the deployprobe.g and retractprobe.g files in the same file location as the config file?
      • RafBundefined
        RafB
        Yes,
        BPisLifeundefined 1 Reply Last reply Reply Quote 0
        • BPisLifeundefined
          BPisLife @RafB
          @rafb I just checked the video. When the pin is deployed does the red light turn off? If not then that’s the issue. The Red light is on when it detects the pin. When the pin is deployed it should be off since well the probe is deployed and not detected.
          Could be a defective bltouch.
          I saw you had another one. Does that have the same issue? If so, can you take a picture of the wiring?
          Also make sure you check the wires for continuity with a DMM.
            Phaedrux Moderator @RafB
            @rafb said in Configurator BLTouch bug:
            What is the correct version of the web server? Why I have 1.21 RC4 after the update?
            Thank you
            You'll need to upload two more files.
            You will need wifi server https://github.com/dc42/RepRapFirmware/releases/download/2.01/DuetWiFiServer-1.21.bin
            And DWC https://github.com/chrishamm/DuetWebControl/releases/tag/1.22
              in a first time this model will go?
              https://www.amazon.fr/dp/B0748FJ48N/ref=cm_sw_r_cp_api_U8QzBb19A3CF4
              This one should work ok hopefully.
              • RafBundefined
                RafB
                Here I am again, always with my problems of bltouch. I will not have a new one because it is holidays and if I order in China, there is a delay of 2 weeks!
                I would like to tell you that I have already managed to print after a complete probing with the bltouch which does not work for the moment.
                The config M558 was P5 H5 F120 T6000
                Due to a problem I can not remember, I could not print anymore. After I got lost in the lines of code that I do not understand then I made the update under your advice and here I am again.
                DC42, I am updating it and I may be able to give you the information you need with this great new web interface. I am not selling the firmware because I can not print but I have no doubt to achieve one day (with or without new bltouch, see even your sensor.
                So tell me where and how to find DWC.
                Phaedrux, thank you for your advice although the delta printer is your forte. I made the update very quickly thanks to you and this ultra simple interface when we understand and we are well helped.
                I have the impression that the problem is actually bltouch but especially a bad code code M558 for these old bltouch.
                As I told you if I run a self-test macro it works perfectly for 15 minutes.
                I retest with this new update and change the parameter M558 P9 H10 F120 T10000 and probing is more point but there is always a time when the bltouch it is in error (flashes).
                here are my files.g
                I thank you again for the help already done and I hope to be quite clear (with google trad) to finally launch quality print.
                A +
                Config.g
                ; generated by RepRapFirmware Configuration Tool on Thu Aug 02 2018 09:35:23 GMT+0200 (CEST)
                ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
                M665 R155 L397.19 B155 H522 ; Set delta radius, diagonal rod length, printable radius and homed height
                M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
                M550 PTEVO LM ; Set machine name
                M551 PSpiral-2321 ; Set password
                M552 S1 ; Enable network
                M587 S"TARM" P"Tino-Ant-Marj-Raf@34" ; Configure access point. You can delete this line once connected
                M586 P0 S1 ; Enable HTTP
                M586 P1 S1 ; Enable FTP
                M586 P2 S1 ; Enable Telnet
                M92 X80 Y80 Z80 E417.22 ; Set steps per mm
                M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
                M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
                M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
                M906 X1000 Y1000 Z1000 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 Z0 S1 ; Set minimum Z
                M574 X2 Y2 Z2 S1 ; Set active high endstops
                M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                M558 P9 H10 F120 T10000 ; Set Z probe type to bltouch and the dive height + speeds
                G31 P25 X0 Y20 Z0.290 ; 1.927 Set Z probe trigger value, offset and trigger height
                M557 R150 S45 ; Define mesh grid
                M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P2 S1 I0 F500 H0 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M563 P0 D0 H1 ; Define tool 0
                ; Automatic power saving
                M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                ; Custom settings
                ;M591 DO C3 P2 E6.0
                M501
                Bed.g
                ; bed.g
                ; called to perform automatic delta calibration via G32
                G28 ; home all towers
                M190 S60
                ;M98 Pdeployprobe.g; déployer sonde mécanique de Z
                ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
                ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                G30 P0 X0 Y132.28 H0 Z-99999
                G30 P1 X121 Y69.86 H0 Z-99999
                G30 P2 X129.9 Y-75 H0 Z-99999
                G30 P3 X0 Y-150 H0 Z-99999
                G30 P4 X-125.9 Y-75 H0 Z-99999
                G30 P5 X-121 Y69.86 H0 Z-99999
                G30 P6 X0 Y59.15 H0 Z-99999
                G30 P7 X56.09 Y32.38 H0 Z-99999
                G30 P8 X64.95 Y-37.5 H0 Z-99999
                G30 P9 X0 Y-75 H0 Z-99999
                G30 P10 X-64.95 Y-37.5 H0 Z-99999
                G30 P11 X-56.09 Y32.38 H0 Z-99999
                G30 P12 X0 Y0 H0 Z-99999 S6
                ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
                ;M98 Pretractprobe.g; rétracter la sonde mécanique Z
                G29
                Deployprobe.g
                ; deployprobe.g
                ; called to deploy a physical Z probe
                ;M280 P3 S160 I1
                M280 P3 S10 I1
                Retractprobe
                ; retractprobe.g
                ; called to retract a physical Z probe
                M280 P3 S90 I1
                RafBundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • RafBundefined
                  RafB @RafB
                  here are my files.g
                  A +
                  Config.g
                  ; Custom settings
                  ;M591 DO C3 P2 E6.0
                  M501
                  Bed.g
                  ; bed.g
                  M190 S60
                  G29
                  Deployprobe.g
                  ; deployprobe.g
                  ;M280 P3 S160 I1
                  M280 P3 S10 I1
                  Retractprobe
                  ; retractprobe.g
                  M280 P3 S90 I1
                    dc42 administrators @RafB
                    @rafb, DWC is short for Duet Web Control. You can find it along with the firmware files at https://github.com/dc42/RepRapFirmware/releases. Chrishamm sometimes has a later version available at https://github.com/chrishamm/DuetWebControl/.
                    • RafBundefined
                      RafB
                      Under the advice of Phaedrux, I installed DWC https://github.com/chrishamm/DuetWebControl/.
                      I would like to know with which parameter I can play so that the bltouch does not put it in default (Blink)
                      When my printer is at home, I measure 517mm from the bed to my nozzle. So I change M665 H522 for the DWC shows me 517 when it is at home. It's correct?
                      I also change M558 P9 H10 and I observed that it was more probing.
                      Do you have any suggestions for modifying M558?
                      thank you
                        Yes if you are using the standard homedelta.g file, which lowers the effector by 5mm after homing so that the nozzle can be safely centred.
                        The H parameter defines the height at which probing starts. So a higher H parameter means probing takes longer (because the probe takes longer to reach the bed), but that it is more tolerant of calibration being a long way out. So we recommend that you used a high H value for initial calibration. Once you have performed calibration and copied the new values into your M665 and M666 commands in config.g, you can reduce the H parameter so that probing takes less time.
