Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released
Firmware installation
19
65
9.8k
    adri84dj
    Good afternoon,
    I do not know if it's my problem, but I've made a couple of impressions with this latest firmware and the latest version of DWC, and it seems that the number of layers does not match the printed layers. My two impressions have finished in 52 of 50 layers
    Greetings.
      whosrdaddy
      @dc42:
      it is inconsistent, it seems not to depend on filesize.
      for completeness, this is my M39 output:
      SD card in slot 0: capacity 7.74Gb, free space 6.93Gb, speed 20.00MBytes/sec, cluster size 32kb
      I did not have this problem on 1.21 firmware.
        gideon
        Hey,
        I just came back somewhere, I wanted to operate the duet with the display just this did not respond well to the commandow, so I wanted to increase the temp but that does not work anymore, this went in firmware 1.21 still normal, this is a known problem
        ? I like to hear this
        thank you in advance
        undefined 1 Reply Last reply 7 Aug 2018, 13:32 Reply Quote 0
          gideon @gideon
          sorry is not due to the firmware, but the touch panel does not work anymore, and I have not had it for a long time @dc42 what about warranty?
          undefined 1 Reply Last reply 7 Aug 2018, 14:14 Reply Quote 0
            dc42 administrators @gideon
            @gideon said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
            Do you mean that the display is working, but the panel does not respond to touch? If so then it's most likely the touch panel on the display that is faulty. If you have the non-integrated version, then it's possible but not very likely that the PanelDue controller board has developed a fault.
            undefined 1 Reply Last reply 7 Aug 2018, 14:22 Reply Quote 0
              gideon @dc42
              @dc42 said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
              I have a separate PanelDue controller card,
              I used the display yesterday, got the printer on again today, and now half of the touchscreen is working
              undefined 1 Reply Last reply 8 Aug 2018, 06:32 Reply Quote 0
                BPisLife @dc42
                This post is deleted!
                  You can try re-running the touch calibration, but if that doesn't work you will need a new display, unless you can find a replacement touch panel for it.
                    Catalin_RO
                    I have made a simple mistake when positioning the raw material on the CNC and the very last set of GCodes were outside the machine limits. As the spindle VFD is controlled through M3 and M5 commands, the GCode file had those as well. The GCodes outside the machine limits have been simply ignored, but the M5 was executed before the already queued moves finished, practically doing the final moves while the spindle was slowing down.
                    Luckily it was just a 2.5D cut, during the final passes, and no harm was really done, but if it were something different the end mill would have broken.
                    Could be added a safety check in the code for M5 to insure that there is no queued move to execute before powering down the spindle?
                    Later: Wrong! It always cuts the power of the spindle before finishing all queued moves!
                    undefined 1 Reply Last reply 9 Aug 2018, 08:02 Reply Quote 0
                      dc42 administrators @Catalin_RO
                      @catalin_ro said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
                      When in CNC mode, with firmware 2.0 and later any attempt to perform movement outside the machine limits should result in an immediate stop. Did this not happen, or are you running older firmware?
                        Catalin_RO
                        It is latest firmware! But it was nothing like an immediate stop...
                        No more GCodes were executed from the file but the already queued ones were allowed to completely finish and the final M5 was also executed, before actually ending any movements.
                        When doing another machining, with everything within machine limits, I found out that the M5 was also executed before all movements were finished (the spindle was actually fully stopped while the end mill was still moving through the material!!!).
                        A quick and dirty workaround was to replace M5 by G4 P0 M5, no properly waiting for any movements to fully finish. Shouldn't M5 wait for the movement queue to be empty before executing by default?
                          mfd
                          I installed a maestro on a printer with a 12864 display. With previous versions of the firmware the display would have the name and a number. Turning the encoder knob would increase or decrease the number.
                          With the latest version I get the following:
                          Error Loading menu
                          File Main
                          Can't open menu file
                          However, pressing the button on the display causes an emergency stop and the SD card reader works as well.
                          From the information that I have found I know it's not something that is fully featured or supported, but what is the current expected behaviour?
                            See https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system.
                            undefined 1 Reply Last reply 11 Aug 2018, 17:34 Reply Quote 0
                              sjason1377 Banned
                              I can't connect to DWC and other than repitier usb to send m552 s1 I have no other way to control machine. Now what do I do? I installed this stable firmware and the DWC found a few line below on same page. Board turns on psu with m80 command when I plug in usb. That might be a repitier thing. I type ip address and nothing. Now I've been printing for more than a year with this, worked with the files many times and read every word of the instructions. I performed every step correctly. I had 1.21rc1 running before this upgrade. and DWC 1.22. now I loaded the versions found in this post and I'm no-longer printing.
                                sjason1377 Banned
                                Router page show ip config as static and full packets sending receiving. It's online full access enabled. But web interface doesn't load.
                                  sjason1377 Banned
                                  I see a blank white window after typing ip in my browser. router show it connected and I don't get an internet connect error. Where is the screen set?
                                  undefined 1 Reply Last reply 11 Aug 2018, 08:43 Reply Quote 0
                                    dc42 administrators @sjason1377
                                    @sjason1377, please send M552 from USB to see whether the Duet is connected t the network and confirm its IP address.
                                      mfd @dc42
                                      It looks like this is still in the early stages. It states that the "following commands will be supported", is the number command currently support? If so, how is the identifier determined?
                                      What I am currently interested in is the current and active temps for tool0 and bed heaters. Maybe the fraction printed.
                                        Items that should be able to be displayed and adjusted where applicable are:
                                        0+n Heater n current temperature
                                        100+n Heater n active temperature
                                        200+n Heater n standby temperature
                                        300+n Fan n speed
                                        399 Current print cooling fan speed
                                        400+n Extruder n extrusion factor
                                        500 Speed factor
                                        This is the value of the N parameter in the 'value' command.
                                        The 'image' command doesn't work yet. The 'files' command doesn't work in my fork, but M3D has a build that implements it. I plan to merge their code into my fork before the 2.02 release.
                                        HTH David
                                          kraegar
                                          Just got to upgrade to 2.01, I'd been at 2.01b2. Got a bit of a surprise.
                                          I'd used some old output from the gcode console to configure my current and microstepping. Specifically around the E field and the number of values. It had reported 9, so I set 9.
                                          In 2.01 I discovered the fun way that if you have more than 7 E values configured, weird things happen:
                                          M906
                                          Motor current (mA) - X:1500, Y:1500, Z:1500, E:0:0:1500:1500:1500:0:0, idle factor 60%
                                          (Similar for M203, forgot to copy it before I fixed it)
                                          Lowering the number of fields in my config.g fixed it. Obviously I shouldn't have had that many, but it was being defined based on the number previously reported:
                                          M203
                                          Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on):16(on):16:16:16:16:16:16:16
                                          Running an extruder with zero current and the incorrect microstepping does some weird stuff!
                                          Edit:
                                          The output at the gcode console was good at explaining what was wrong, so I fixed it quickly once I realized there was an issue:
                                          M906 X1500 Y1500 Z1500 E700:1500:1500:1500:1500:1500:1500:1500:1500 I60
                                          Error: GCodes: Attempt to read a GCode float array that is too long: M906 X1500 Y1500 Z1500 E700:1500:1500:1500:1500:1500:1500:1500:1500 I60
                                          Last edit: I see this was covered in the release notes in whatsnew. I just missed it. This is just a bit of insight on what happens in that case. Carry on!
                                          54 out of 65
