    Motors much louder than on MKS+TMC2208
    motors sound loud
    1.8k
    • Stephanundefined
      Stephan
      Dear All.
      I had a hard time to pay the price for my duet wifi. Until now i only have the board itself.
      My printer is a tronxy X3s, which is a CR 10 clone.
      Before switching to duet i used MKS 1.4 with TMC2208 drivers. It was not noticeable, even if the drives were moving.( slower than 50mm/s)
      Now with duet wifi i have whining noise during idle and a lot louder movement sounds in comparision to MKS + TMC2208.
      I have seen many threads pointing to wiring/lower current and such. So the only thing changed here is the duet board as the motors were
      quiet before. In result i wont bet on wiring as the documentation is very good for duet. What can i do?
      Stepper motors are 1.8° "Chinesian Brand". here is my configuration:
      ; generated by RepRapFirmware Configuration Tool on Mon Aug 13 2018 00:16:32 GMT+0200 (Mitteleuropäische Sommerzeit)
      G90                            ; Send absolute coordinates...
      M83                            ; ...but relative extruder moves
      M550 PRainer                   ; Set machine name
      M552 S1                        ; Enable network
      M587 S"Funkefiez 2" P"d3rd1gg3"; Configure access point. You can delete this line once connected
      M586 P0 S1                     ; Enable HTTP
      M586 P1 S1                     ; Enable FTP
      M586 P2 S1                     ; Enable Telnet
      M569 P0 S0                     ; Drive 0 goes backward - X
      M569 P1 S0                     ; Drive 1 goes backward - Y
      M569 P2 S1                     ; Drive 2 goes forwards
      M569 P3 S1                     ; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1 S3		; Configure microstepping with interpolation
      M92 X80 Y80 Z400 E95.2         ; Set steps per mm
      M566 X15 Y15 Z2 E2               ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z300 E3000    ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z100 E1000    ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I40   ; Set motor currents (mA) and motor idle factor in per cent
      M84 S0                       ; Set idle timeout
      M208 X0 Y0 Z0 S1               ; Set axis minima
      M208 X300 Y300 Z300 S0         ; Set axis maxima
      M574 X1 Y1 S0                  ; Set active low endstops
      M574 Z1 S2                     ; Set endstops controlled by probe
      M558 P1 H5 F120 T6000          ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X35 Y5 Z2             ; Set Z probe trigger value, offset and trigger height
      M557 X40:280 Y20:280 S20       ; Define mesh grid
      M143 H0 S120                   ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280                   ; Set temperature limit for heater 1 to 280C
      M106 P0 S0.3 I0 F500 H-1       ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45      ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T45      ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                  ; Define tool 0
      G10 P0 X0 Y0 Z0                ; Set tool 0 axis offsets
      G10 P0 R0 S0                   ; Set initial tool 0 active and standby temperatures to 0C
      As its done my config creation tool its very stock. I tried to set S3 on M350 as it feels that its not using stealthchop? Nothing changed.
      Thanks
      derdigge
      EDIT: added codeblock.
        Use S1 to enable interpolation.
        Motor idle noise can often be reduced by changing the off-time in the stepper driver configuration. There is a thread about how to do this (search for "motor idle noise"). It's even easier in the new 2.02beta1 firmware, because there is a separate M569 parameter to set the off time.
        • wilrikerundefined
          wilriker @Stephan
          @stephan said in Motors much louder than on MKS+TMC2208:
          Duet Wifi does not support stealthChop but only spreadCycle. I am not sure what will be selected when you use S3 here but I guess it will fall back to spreadCycle.
          As to reducing stand-still noise as @dc42 mentioned look at [Reducing Stand-Still Noise].(https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise).
          What are the specs of your motors? Especially rated current, resistance and inductance?
          Manuel
          My Tool Collection
          • Stephanundefined
            Stephan
            Thanks for the answers.
            @dc42 said in Motors much louder than on MKS+TMC2208:
            Forgot to mention, i am allready on latest beta.
            @wilriker said in Motors much louder than on MKS+TMC2208:
            Hard to say about the specs. They are stock tronxy and no data available. They are Nema17 40mm long.
            nothing googleable.(i know that this do not help)
            Duet wifi does not support stealthChop ? Seriously?
            regardig to this:
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M350_Set_microstepping_mode
            There is a switch?
            EDIT added board diag:
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet WiFi 1.02 or later
            Board ID: removed
            Used output buffers: 3 of 20 (7 max)
            Static ram: 28484
            Dynamic ram: 95996 of which 0 recycled
            Exception stack ram used: 324
            Never used ram: 6268
            Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3592)
            Owned mutexes:
            Last reset 00:01:56 ago, cause: software
            Last software reset at 2018-08-13 15:36, reason: User, spinning module GCodes, available RAM 6284 bytes (slot 0)
            Error status: 0
            Free file entries: 10
            MCU temperature: min 50.5, current 50.7, max 51.0
            Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
            Driver 0: standstill, SG min/max 41/128
            Driver 1: standstill, SG min/max 0/185
            Date/time: 2018-08-13 15:38:45
            Slowest loop: 7.42ms; fastest: 0.07ms
            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 239, MaxWait: 11369ms, Underruns: 0, 0
            Scheduled moves: 28, completed moves: 28
            Bed compensation in use: none
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 9.19ms; fastest: 0.01ms
            HTTP sessions: 1 of 8
            - WiFi -
            Network state is running
            WiFi firmware version 1.19
            WiFi MAC address 60:01:94:7e:eb:a8
            WiFi Vcc 3.10, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 37360
            WiFi IP address 192.168.2.120
            WiFi signal strength -44dBm, reconnections 0, sleep mode unknown
            === Expansion ===
            • wilrikerundefined
              wilriker @Stephan
              OK, I know this from my motors (coming from an Anet A8).
              regardig to this:
              There is a switch?
              Yes, there is a switch but the documentation also says
              the Duet 2 Wifi/Ethernet supports modes 0, 1 and 2.
              The Duet 2 Maestro supports modes 2 and 3
              Where 2 is spreadCycle and 3 is stealthChop.
              So as you can see stealthChop is only supported with the Duet Maestro as it uses different drivers (TMC2240 IIRC). TMC2660 as used on Duet Wifi/Ethernet do not support stealthChop.
              Manuel
              My Tool Collection
              • Stephanundefined
                Stephan
                Damn. i wish i had read further...
                This is a dealbreaker for me.
                  As you are using the latest beta, try reducing the off-time using the new F parameter of the M569 command. For example, send M569 P0 to find the current parameters of the X motor, and M569 P0 F# to change the off-time, where # is the new off-time.
                  • Stephanundefined
                    Stephan
                    Thanks for the helping hands here, really.
                    After few days of testing i am sure i will go back. The Gcode driven System and the Webinterface are really great.
                    It prints currently on my tronxy but its simply to loud. I tried an stepper from stepper online on y axis i have arround but its the same.
