    my delta printer seems to have a mind of its own
    1.3k
    • dmkmediaundefined
      dmkmedia
      I have a Kossel XXL delta and I have been trying to get it right for over a week now
      but it seems to have a mind of its own
      the auto delta calibration won't touch the bed no matter what I set it I now have my Z set to -5 but it still won't go down. the endstop hit just says yes most of the time.
      also, the home all option sometimes works then sometimes find the end stops lowers down then shoots off 20mm or so in one direction.
      i just can't get it to print anything correctly. if i do manage to get a level and start a print something always messes it up whether it be it starts printing off center or it just doesn't touch the bed. and once it just stopped and stabbed my print.
      it seems to have a mind if its own noting is constant
      Software Information
      Firmware Version: 2.01(RTOS) (2018-07-26b2)
      WiFi Server Version: 1.21
      Web Interface Version: 1.21.2-dc42
      Config.g
      *; generated by RepRapFirmware Configuration Tool on Thu Jul 19 2018 15:05:44 GMT+0100 (British Summer Time)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R200 L400.30 B120 H413 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X-10 Y-7 Z-10 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PDelta Printer ; Set machine name
      M552 S1 ; Enable network
      ;*** Access point is configured manually via M587
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P3 S0 ; Drive 3 goes forwards
      M350 X16 Y16 Z16 I1
      M350 E8 ; Configure microstepping with interpolation
      M92 X80 Y80 Z80 E1900 ; Set steps per mm
      M566 X1000 Y1000 Z1000 E6 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E2400 ; Set maximum speeds (mm/min)
      M201 X1800 Y1800 Z50 E50 ; Set accelerations (mm/s^2)
      M906 X1200 Y800 Z800 E400 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M579 X0.966 Y0.978
      M208 Z-5 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S0 ; Set active high endstops
      M558 P5 R0.5 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.256 ; Set Z probe trigger value, offset and trigger height
      M557 R140 S20 ; Define mesh grid
      M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S300 ; Set temperature limit for heater 1 to 300C
      M106 P0 S1 I0 F500 H-0 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; Custom settings are not configured*
      Bed.g
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; Probe the bed at 3 peripheral and 0 halfway points, and perform 3-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y110 H0 Z-99999
      G30 P1 X0 Y-110 H0 Z-99999
      G30 P2 X110 Y0 H0 Z-99999
      G30 P3 X-110 Y0 H0 Z-99999
      G30 P4 X-90 Y20 H0 Z-99999
      G30 P5 X-90 Y20 H0 Z-99999
      G30 P0 X0 Y0 H0 Z-99999 S6
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
      https://dmkitservices.com
        @dmkmedia said in my delta printer seems to have a mind of its own:
        The fix for that is to increase the H parameter in M558 until you have completed first-time calibration, as recommended at https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer. You could also check the H parameter in your M665 command, which I suspect is much too low.
        It sounds like one of the carriages doesn't always reach the endstop. See this bit of the FAQ page https://duet3d.dozuki.com/Wiki/FAQ#Section_When_I_try_to_home_my_printer_sometimes_the_carriage_or_carriages_move_only_part_of_the_way_towards_the_homing_switches_and_I_have_to_command_it_to_home_again_to_make_it_go_all_the_way.
        • dmkmediaundefined
          dmkmedia
          @dc42 said in my delta printer seems to have a mind of its own:
          they do hit the endstops and i have watched them connect i click go to home repeatedly and it still does it until a turn it off and back on then all is ok. until the next time, it starts to do it
          I have now set the M558
          M558 P5 R0.5 H30 F1200 T6000
          and still it fails to touch the bed on some of the tries here is a video i start at
          X,0 Y,0 Z,0
          as shown on the video
          https://youtu.be/01zD6HJANLA
          at 39 seconds is the one where it goes nowhere near the bed
          but its totally random the one after this it didn't touch in 3 places
          • adavidmundefined
            adavidm
            It might just be a perspective trick, but is the effector level at all times in that video? It looks to me like it's tilting, based on the way the bubble in the spirit level is moving. Are you using the Duet3D PCB magnetic carriage adapters?
            0_1534262369588_ae244722-81e1-477a-a556-4bea3b518d33-image.png 0_1534262421794_dec8cdc1-2b23-41a5-b40e-5735a2b32035-image.png
            Also, difficult to tell in the video, but is the effector registering a hit when it stops in mid-air at 40 seconds?
            adavidm
            dmkmediaundefined 1 Reply Last reply Reply Quote 0
              I agree with adavidm, you may be getting a false trigger. When it stops before reaching the bed, does the green LED on the effector flash?
              If yes -> false triggering due to too much vibration, or possibly a faulty effector. Please run M350 to check that you are running x16 microstepping with interpolation enabled. From the video, your machine does sound a little noisy when probing, so perhaps you are using lower microstepping, or no interpolation.
              If no -> check that the connections between the 8-way connector on the effector and the Duet are sound.
              • Danalundefined
                Danal @dmkmedia
                @dmkmedia
                The effector IS tilting. It is very clear when the video is played several times. This indicates a problem with the mechanics. Nothing will work until this is cleared up.
                Please post a photo of the carriages. There is one very blurry frame where the carriages show... and there seems to be no sign of the carriage adapters. They are the rectangular things in this photo.
                • dmkmediaundefined
                  dmkmedia @Danal
                  @danal said in my delta printer seems to have a mind of its own:
                  @dmkmedia
                  They are not fitted as they would not fit to the carriages so I printed one with the measurements on the site with one that would fit
                  adavidmundefined 1 Reply Last reply Reply Quote 0
                  • dmkmediaundefined
                    dmkmedia @adavidm
                    @adavidm it measures a hit when it's sitting still on and off.
                    • dmkmediaundefined
                      dmkmedia @dc42
                      @dc42 as per config file above
                      M350 X16 Y16 Z16 I1
                      • dmkmediaundefined
                        dmkmedia
                        Could it be the tower is too tall at 1000mm
                        • Danalundefined
                          Danal @dmkmedia
                          I have a working delta with 1500MM towers (that have 1000MM linear slides) and 700mm Hayden Huntley arms. At this instant, that printer is powered off due to the room that it is in being flooded (long story), so I can't easily retrieve the config.
                          Just wanted you to know that printers that big or bigger do work.
                          • Danalundefined
                            Danal
                            And, I believe you have at least two problems to clear up: False trigger (which others can help you with) and a mechanical problem that is tilting your effector. Until the effector tilt is fixed, nothing else is going to work correctly.
                            If you measure between a pair of diagonal rods, near the effector, is this the EXACT same as a measure between the rods near the carriage?
                            Sorry for crappy backlit photos... but they will get the idea across.
                            • adavidmundefined
                              adavidm @dmkmedia
                              As others have said, it's almost certainly the source of the tilt and you must fix this before going any further. the rod pairs need to be absolutely parallel for the effector to stay level. One of the clever aspects of the Smart Effector design was in using the excellent precision of a manufactured PCB to ensure that the Mag ball holes are perfectly spaced.
                              If you are getting false readings from the strain gauge on the Smart Effector, that's going to prevent auto calibration from working. Worth double-checking crimps and any other connections, just in case you are getting an intermittent connection fault.
                              For now, I'd concentrate on the tilt issue. If you can take a clear photo of your carriage mounts, maybe someone can offer advice on how to get the PCB adaptor to fit.
                              adavidm
