    Mesh Grid Compensation
    3.3k
    • Puppet172undefined
      Puppet172
      i changed it and made it lower but then i still got this
        Did you run the test that I suggested in my first reply?
        Puppet172undefined 1 Reply Last reply Reply Quote 0
          Puppet172 @dc42
          Yes I tried that too got the pretty much the same this as the last one I just posted.
            dc42 administrators @Puppet172
            @puppet172 said in Mesh Grid Compensation:
            I meant this one:
            To test this, place the nozzle over the bed and send G1 Z5 and G30 S-1 alternately. The G30 S-1 command should report about the same trigger height each time. If it reports increasing trigger heights, you are probing too fast. Reduce the F parameter in the M558 command until you get a consistent result.
              Puppet172 @dc42
              Yes it would go up a little by little like 4.303 to 4.350 and so on, sometimes it would eventually level out i then changed the F from i think 120 to 100 and then it seemed to level out right away to about .01 of a mm
                What M201 and M203 Z parameters are you using, and what is your Z steps/mm?
                  Puppet172 @dc42
                  M92 X80 Y80 Z2000 E100.1 ; Set steps per mm
                  M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X6000 Y6000 Z100 E1200 ; Set maximum speeds (mm/min)
                  M201 X500 Y20 Z350 E250 ; Set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30
                    Your Z acceleration in M201 looks very high for 2000 steps/mm. I suggest you reduce it to around 40. OTOH your Y acceleration looks very low for 80 steps/mm.
                      Puppet172 @dc42
                      @dc42 I think you got my m92 and m201 mixed up because my m92 z is 2000 but my m202 isn’t
                        @puppet172, I was referring to your M201 Z350.
                          Puppet172 @dc42
                          What would you recommend putting it at ?
                            40, as I said before.
                            Puppet172undefined 2 Replies Last reply Reply Quote 0
                              Puppet172 @dc42
                              I will put it at 40 and then I will do another mesh bed and then post it
                                Puppet172 @dc42
                                • Nylkosundefined
                                  Nylkos
                                  Did you set you Z by "Home Z" or do you adjust with a piece of paper and G92 Z0?
                                  I might be wrong but if your home Z and your offset isn't setup, that could cause the issue if before running M92 you your whole M92 should be off.
                                  I will explain, if you home with your probe and your 0 is really 3mm, you then home with a piece of trigger and fix the difference but that will cause that when you run M92 and your probe triggers, they will assume that your are always minimun 3mm off...
                                    Puppet172 @Nylkos
                                    @nylkos
                                    how do i set the offset?
                                      What type of Z probe are you using?
                                        Puppet172 @dc42
                                        uxcell LJ12A3-4-Z/AX 3-Wire DC6-36V 300mA NPN NC 4mm Inductive Proximity Sensor Switch https://www.amazon.com/dp/B00S50O152/ref=cm_sw_r_cp_api_OUWEBb2TQTHR5
                                          You can find your trigger height with this
                                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                            Please post your complete config.g, homeall.g and homez.g files, and tell us how you have connected the inductive sensor to the Duet.
