    Adding drivers to Duex2...
    • Mangy_Dogundefined
      Mangy_Dog
      From what I can tell the Duex to and 5 PCB is identical. Only that the 2 has a few missing components.
      Is there any reason at all why it wont be possible to add the TMC2660 driver header to the unused solder pads to expand the motor controllers?
      I ask as currently Im only going to need 7 drivers hence the 2... but if such a reason later comes up to need 8 or 9 or even 10, rather than buy another board. Just adding the drivers to the board would be better...
      Does Duet sabotages the unused pads?
      Id imagin it would be a lot cheaper just upgrading the board hardware than buying a whole new board...
        We don't sabotage the X2 in any way, but of course we don't test that whether it could support the x5 functionality. To convert a latest version X2 to X5 you would need to add the additional drivers and connectors, and add/remove some 0 ohm resistors. See the schematic at https://github.com/T3P3/Duet/blob/master/Duet_Expansion/Duex5v0.8/Duex5v0.8_Schematic.pdf.
          Mangy_Dog
          Ahh good, thanks 🙂 Thought it would be fairly simple, i just ordered the wifi and duex2 😄 been spending lots on this new build... its making the pocket light and me light headed...
            If you are feeling light-headed, maybe we can sell you a Smart Effector too? (Only joking!) ☺
              Mangy_Dog
              @dc42 said in Adding drivers to Duex2...:
              Smart Effector
              Lucky for me im not building a delta 😛
