    bltouch retraction when homing
    Duet Web Control wishlist
    • adri84djundefined
      adri84dj
      Good Morning.
      Is it possible that the homimg button of the web control includes the bltouch retract function?
      a greeting.
        If you are using recent firmware then deployment and retraction of the Z probe should happen automatically if you are using G30 to home Z.
        adri84djundefined 1 Reply Last reply Reply Quote 0
        • adri84djundefined
          adri84dj @dc42
          but pressing homing all that is a G28 does not. I have a kossel.
            So you are not homing Z using the BLTouch. In that case, the BLTouch should already be retracted when you start. If you want to make sure, you can put the M280 command to retract and/or reset the BLTouch at or near the end of config.g, or in homedelta.g.
            • adri84djundefined
              adri84dj @dc42
              @dc42 said in bltouch retraction when homing:
              Ok. thanks 😉
