Changing XYZ minimum
I've just moved my Y endstop so i get the nozzle a little longer away from the bed when homed. And since i've done that i would like to change the "Y minimum" from -26mm to -30mm but i can't find it anywhere?
Have you read about on M208?
It is used to set max and min travel for X, Y and/or Z.
I think that is what you are asking about.
Your 100% right!
