    Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released
    Firmware installation
    19
    65
    9.8k
    • mfdundefined
      mfd
      I installed a maestro on a printer with a 12864 display. With previous versions of the firmware the display would have the name and a number. Turning the encoder knob would increase or decrease the number.
      With the latest version I get the following:
      Error Loading menu
      File Main
      Can't open menu file
      However, pressing the button on the display causes an emergency stop and the SD card reader works as well.
      From the information that I have found I know it's not something that is fully featured or supported, but what is the current expected behaviour?
        See https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system.
        mfdundefined 1 Reply Last reply Reply Quote 0
        • sjason1377undefined
          sjason1377 Banned
          I can't connect to DWC and other than repitier usb to send m552 s1 I have no other way to control machine. Now what do I do? I installed this stable firmware and the DWC found a few line below on same page. Board turns on psu with m80 command when I plug in usb. That might be a repitier thing. I type ip address and nothing. Now I've been printing for more than a year with this, worked with the files many times and read every word of the instructions. I performed every step correctly. I had 1.21rc1 running before this upgrade. and DWC 1.22. now I loaded the versions found in this post and I'm no-longer printing.
            sjason1377 Banned
            Router page show ip config as static and full packets sending receiving. It's online full access enabled. But web interface doesn't load.
              sjason1377 Banned
              I see a blank white window after typing ip in my browser. router show it connected and I don't get an internet connect error. Where is the screen set?
                dc42 administrators @sjason1377
                @sjason1377, please send M552 from USB to see whether the Duet is connected t the network and confirm its IP address.
                • mfdundefined
                  mfd @dc42
                  It looks like this is still in the early stages. It states that the "following commands will be supported", is the number command currently support? If so, how is the identifier determined?
                  What I am currently interested in is the current and active temps for tool0 and bed heaters. Maybe the fraction printed.
                    Items that should be able to be displayed and adjusted where applicable are:
                    0+n Heater n current temperature
                    100+n Heater n active temperature
                    200+n Heater n standby temperature
                    300+n Fan n speed
                    399 Current print cooling fan speed
                    400+n Extruder n extrusion factor
                    500 Speed factor
                    This is the value of the N parameter in the 'value' command.
                    The 'image' command doesn't work yet. The 'files' command doesn't work in my fork, but M3D has a build that implements it. I plan to merge their code into my fork before the 2.02 release.
                    HTH David
                    • kraegarundefined
                      kraegar
                      Just got to upgrade to 2.01, I'd been at 2.01b2. Got a bit of a surprise.
                      I'd used some old output from the gcode console to configure my current and microstepping. Specifically around the E field and the number of values. It had reported 9, so I set 9.
                      In 2.01 I discovered the fun way that if you have more than 7 E values configured, weird things happen:
                      M906
                      Motor current (mA) - X:1500, Y:1500, Z:1500, E:0:0:1500:1500:1500:0:0, idle factor 60%
                      (Similar for M203, forgot to copy it before I fixed it)
                      Lowering the number of fields in my config.g fixed it. Obviously I shouldn't have had that many, but it was being defined based on the number previously reported:
                      M203
                      Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on):16(on):16:16:16:16:16:16:16
                      Running an extruder with zero current and the incorrect microstepping does some weird stuff!
                      Edit:
                      The output at the gcode console was good at explaining what was wrong, so I fixed it quickly once I realized there was an issue:
                      M906 X1500 Y1500 Z1500 E700:1500:1500:1500:1500:1500:1500:1500:1500 I60
                      Error: GCodes: Attempt to read a GCode float array that is too long: M906 X1500 Y1500 Z1500 E700:1500:1500:1500:1500:1500:1500:1500:1500 I60
                      Last edit: I see this was covered in the release notes in whatsnew. I just missed it. This is just a bit of insight on what happens in that case. Carry on!
                      • SputnikOC3dundefined
                        SputnikOC3d
                        Neither M561 nor G29 S2 adjusted the user Z coordinate if bed compensation was previously active (G29 S2 did if you ran it twice)
                        From the release notes and not mentioned in later releases ... Im not sure I understand from this bug fix description, what this means and is doing ... but suspect it may resolve an issue I have been experiencing from day 1 on my cartesian Prusa MK3 style printer and mesh bed leveling and Z height adjusting on Layer 1
                        I can never really seem to get a stable proper 1st layer height between prints and have to make rather large adjustments [ Z height baby stepping ] between prints and manually dial in Z with baby stepping - every print - even when printing on the same day or within the same hour.
                        It always seem like the layer height adjustments were being compounded or stacked - even if I ran M561 between. Only way to seem to get a fresh start was a reboot of the machine. And then the baby step dial in after Mesh Bed Comp was run and Dual Z lead screw tilt correction macros were run.
                        Im currently on 2.0 - wondering if this is a potential fix for my issue[s]
