    How do you maintain the hot end temperature?
    1.1k
    • appjawsundefined
      appjaws
      The hot end heater has been auto tuned.
      During a print the secondary cooling fan started at 50% speed for bridging and the hot end temperature dropped dramatically by 5 or 6 degrees.
      The print failed because the filament was not as hot as it should have been.
      Eventually over a 2-3 min period the heater recovered to the set temperature but it was too late to save the print.
      How can I improve the response time of the heater when the heater temperature is reduced by cooling?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • Sniffleundefined
        Sniffle
        Try tuning it with all fans running 100% that should solve the problem.
        • appjawsundefined
          appjaws
          That's a good idea but before I try it, how do you think the hot end performance will be affected when the fan is not running?
          Simplify3D 5.1.2
          • Sniffleundefined
            Sniffle
            That's what pid does it maintains the temp by lowering pwm frequency to maintain the target temp. It's also how I tuned my hotend and it works just fine 🙂
            I would suggest using the suggested max pwm from the wiki so that you get full performance from the heater.
            • appjawsundefined
              appjaws
              Thank, I'll try that.
              The auto tune using the default 0.5 failed when I tried it before but of course I didn't have the fan on then.
              Simplify3D 5.1.2
                @appjaws:
                That's odd because with 1.15c firmware, the temperature should recover faster than it did with older firmwares, unless you were using very aggressive PID parameters. You can go back to your old PID parameters if you wish, just be sure to put the M301 command later in config.g than the M307 command, and double/halve the I and D parameters.
                How do the load change PID parameters displayed by M307 compare with the PID parameters you used to use?
                • appjawsundefined
                  appjaws
                  @dc42, @Sniffle
                  The old setup just used the default PID settings in the firmware.
                  I hope to test this weekend and auto tune with the external fan running.
                  Thanks for your help
                  Simplify3D 5.1.2
