Fan connectors dont work anymore
1.2k
    mickey30m
    my fan connectors dont work anymore. i had a couple of weeks ago a short on my fan, since that time i have my fan and layer fan on my psu. but now i want to fix this problem.
    is there a fuse somewhere? of should i look on something.
    i get about 1 volt on my always on fan connector.
    and how do you call the connectors on the board. (the white ones) it is jst? i broke some, so i want to change that.
      See https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers.
      undefined 1 Reply Last reply 22 Sept 2018, 08:06 Reply Quote 0
        mickey30m @dc42
        @dc42 wow thanks i dont know that page.
        i order the parts
        many thanks
        undefined 1 Reply Last reply 23 Sept 2018, 07:18 Reply Quote 0
          dc42 administrators @mickey30m
          @mickey30m, the connector part numbers on that page are for the shells and crimps that fit on the cables, but if you look up those part numbers you will find the part numbers for the connectors that you want to replace on the board.
          If your Duet is a version 1.03 or 1.04 then the reason the fans don't work is most likely that the 1A blade fuse has blown.
          undefined 2 Replies Last reply 24 Sept 2018, 17:48 Reply Quote 0
            mickey30m @dc42
            @dc42 i have a 1.04
            okay thanks i ordered some so i hope there will be soon delivered.
            maybe time for another duet. for my other printer 😉
              mickey30m @dc42
              @dc42 link text is this the right one, i dont can buy it from farnell because they dont accept my creditcard for some reason.
                No that's not the right mosfet. Search for PMV40UN2.
                undefined 1 Reply Last reply 4 Oct 2018, 04:55 Reply Quote 0
                  mickey30m @dc42
                  @dc42 ![alt text](2_1538628932470_October 04, 2018 at 0649AM.jpg 1_1538628932470_October 04, 2018 at 0648AM.jpg 0_1538628932469_October 04, 2018 at 0647AM.jpg image url)
                  someone tell me if the mosfet is done??
                  ;-)_
                    Sometimes when the mosfets fail there is a hole or burn mark in them, but those look OK.
                    Do the always-on fan connectors work? If not, then the blade fuse has probably blown.
                    undefined 2 Replies Last reply 4 Oct 2018, 17:41 Reply Quote 0
                      mickey30m @dc42
                      @dc42 blade fuse is the blue (car fuse) ?
                      I now have disconnected everything so i will check IT and put power on it to test
                      Question when i disconnected everything and power the board. And in web control i slide the fan on. It will put power on the fan connector?
                        mickey30m @dc42
                        @dc42 when i measure the volts. i get on the left connector. 0.00 and on the other connectors 0.15volt
                        @dc42 an idea why?
                        i dont see things that are damaged
                        5 out of 11
