    M906 reports E:0 on update to 1.19.2
    Firmware installation
    1.9k
    • madhunmundefined
      madhunm
      I seem to be having the same issue with firmware version 2.01
      It starts off with 0mA current; when I type in M906 E(any current over 1000ma), it starts to work fine.
      Here is my excerpt from config.g:
      M906 X2000 Y1500 Z1500 U1500 E1500:1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      Thanks,
      Madhu.
        dc42 administrators @madhunm
        @madhunm, please post your whole config.g file.
        • madhunmundefined
          madhunm
          @dc42 said in M906 reports E:0 on update to 1.19.2:
          here it is:
          0_1537895572014_config (2).g
            Phaedrux Moderator @madhunm
            @madhunm Try retyping the line from scratch in the config.
            • madhunmundefined
              madhunm
              @phaedrux said in M906 reports E:0 on update to 1.19.2:
              Done; no use.
              After rebooting, M906 in the console results in:
              M906
              Motor current (mA) - X:2000, Y:1500, Z:1500, U:1500, E:0, idle factor 30%
                What happens if you use E1500 in config.g instead of E1500:1500 ?
                What happens if you enter that M906 command in the GCode Console, exactly as you have it in config.g?
                • madhunmundefined
                  madhunm
                  When i use E1500, it works as expected; M906 reports:
                  Motor current (mA) - X:2000, Y:1500, Z:1500, U:1500, E:1500, idle factor 30%
                  When I type E1500:1500 in the gcode console, i get:
                  Error: GCodes: Attempt to read a GCode float array that is too long: M906 E1500:1500
                  Thanks,
                  Madhu.
                    @crperryjr said in M906 reports E:0 on update to 1.19.2:
                    M92 E146.27:146.27:146.27 ; Set steps/mm for extruders
                    I just noticed that your M92 for the E steppers steps per mm comes much later than for the other axis and after your other commands specify settings for a single E motor.
                    Try moving your e steps per mm M92 back up with your other axis.
                      @madhunm said in M906 reports E:0 on update to 1.19.2:
                      Thanks,
                      Madhu.
                      That's as expected. Your config.g file contains this line:
                      M584 X0 Y1 Z2:3 U3 E4 P4
                      So you have only one extruder drive (E4 in the M584 command), not two.
                      • madhunmundefined
                        madhunm
                        That's as expected.
                        Thanks a ton for your support! 🙂
