    Help with problem print
    • lukas.aurarumundefined
      lukas.aurarum
      I had this model printed on my main printer and got this thicker back appearing on surface.
      i then turned on pressure advance and print great
      i got a second printer that had a marlin board which printed the same model fine.
      installed duet, and printed the same band.
      so i turned on pressure advance, but the band is still there.
      all printers are direct drive.
      just can figure it out, any suggestions?
      0_1539320839393_20181012_150914_resized.jpg 0_1539320855611_20181012_150837_resized.jpg
      • ozgiacundefined
        ozgiac
        Solved.
        Was due to Maximum speed and acceleration of extruder not set high enough.
