M208 Axis Limits confusion
And another question for you guys
In my config.g, I set the following:; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X300 Y300 Z300 S0 ; Set axis maxima
Unfortunately, I don't get the high-end / low-end scheme 100%
My endstops are positioned (seen from the top-front of the printer) left for X and on the back for Y.How would I need to set the M208 values to have 0/0 in the front left corner?
Thanks for any help to guide me! -
What you have is correct. You also need to tell the firmware which way the X and Y axis motors move in the M569 commands for the X and Y motor drivers, and whether the X and Y endstops are at the low (zero) or high (300) ends of the axes.
Thanks for the reply.
I have set them as follows:M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes backwards
What would I have to do to achieve my goal to have 0/0 in the front left corner?
I found the culprit.
Y Endstop was set to the low end instead of high end.
Thank you all -
@Royce How do you specify if an end-stop is at the low-end or the high-end?M574, sorry didn't check good enough...
