    Your Duet rejected the HTTP request: page not found
    Firmware installation
    20.4k
      Have you seen this?
      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
      • sleeplessundefined
        sleepless
        ok just read through it and I am more confused.
        File config.g:
        ... Im not sure what I would put here:
        M584 X0 Y1 Z2:5:6 ; three Z motors connected to driver outputs 2, 5 and 6
        M671 X-15💯215 Y190:-10:190 S0.5 ; leadscrews at rear left, front middle and rear right
        File bed.g:
        I assume I would remove M401 and G30 P2 X100 Y10 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
        M402 ; retract probe?
        G28 ; home
        M401 ; deploy Z probe
        G30 P0 X20 Y190 Z-99999 ; probe near a leadscrew
        G30 P1 X180 Y190 Z-99999 ; probe near a leadscrew
          @phaedrux said in Your Duet rejected the HTTP request: page not found:
          Well in your case you only have 2 motors and 2 lead screws, so in those examples you just need to remove one of the references for each and make the remaining ones match your setup.
          So something like M584 X0 Y1 Z2:4 assuming your Z motors are connected to the Z connector and the second extruder connector (e1)
          And then you'd need your lead screw positions M671 X-15:315 Y150:150 assuming the lead screws are in the middle of the bed in the Y dimension, and then a left and right value for the X axis.
          and for the bed.g same deal, you just need 2 positions for your 2 lead screws.
          I'm not an expert on using independent lead screws to level the bed though as I've never used it.
            sleepless
            my z motors are both connected in the port z motor a and port z motor b
              sleepless
              fyi i am using duet 2 wifi
                sleepless
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool on Sun Oct 28 2018 16:32:40 GMT-0700 (Pacific Daylight Time)
                ; Probe the bed at 4 points
                G30 P0 X15 Y15 H0 Z-99999
                G30 P1 X15 Y239 H0 Z-99999
                G30 P2 X215 Y239 H0 Z-99999
                G30 P3 X215 Y15 H0 Z-99999 S
                  sleepless
                  I dont have m584 in my config.g anywhere
                    sleepless
                    anyone around?
                      sleepless
                      anyone home?
                        The link provided above lists the requirements for getting the leveling to work.
                        As I said, the motors will need to be connected to separate drivers.
                        The bed.g you just posted will not work, because you do not have a Z probe. The best you can do is tilt correction of the X axis to keep the Z motors aligned properly. To do anything more will require an actual Z probe.
                          sleepless
                          Sorry bud but I dont understand what you are telling me to do
                            sleepless
                            as i mentioned there is no m584 in my config.g
                              sleepless
                              Ya that link makes zero sense to me since i dont see those codes in my config.g
                                sleepless
                                Can anyone just create the proper config.g for me this is taking way too long
                                  sleepless
                                  ive read the links and nothing seems to be working
                                    sleepless
                                    ive uploaded the .g files
                                    does anyone see what I am doing wrong?
                                      sleepless
                                      This is insane How long this is taking!
                                        sleepless
                                        When will you offering phone support?
                                          sleepless
                                          is anyone therre?
                                            sleepless
                                            Perhaps I can skype with support?
