    Your Duet rejected the HTTP request: page not found
    Firmware installation
    20.4k
    • sleeplessundefined
      sleepless
      // default settings
      #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,800,723.38} // default steps per unit for RoBo 3D R1
      I used the above when creating the config in the reprap website. I believe i chose 32steps
      M569 P0 S0 ; Drive 0 goes forwards
      M569 P2 S0 ; Drive 2 goes forwards
      M569 P3 S0 ; Drive 3 goes forwards
      M350 X32 Y32 Z32 I0 ; Configure microstepping without interpolation
      M350 E16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z800 E723.38 ; Set steps per mm
      M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z300 E1500 ; Set maximum speeds (mm/min)
      M201 X500 Y250 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
        sleepless
        ok i doubled my e steps and now it looks appropriate. I will go ahead and run the test and calibration again now
          sleepless
          when i try to configure and claibrate the z probe. I center the x and y after homing them.then lower the z until it grips paper and send the g92 z0 command. zeros out the z.
          then i raise the nozzle by 5 and run g30 s-1 and the nozzle is too close to the bed. the values are still negative.
          What am I doing wrong here. I cant seem to get it to probe and leave the nozzle at the correct height for it to grip the paper
            sleepless
            tried a test print
            and got Error: Z probe already triggered at start of probing move
            Error: G29: No valid grid defined for bed probing
              sleepless
              G28 ; home all axes
              G29 ; probe the bed
              G1 Z5 F5000 ; lift nozzle
              M109 S[extruder0_temperature] ; set the extruder temp and wait
              G1 X0 Y0 ; move to begin wipe
              G1 X20 Z0 F4800 ; wipe here is my beiginingg script for S3D
                sleepless
                do i need to change g29 to m557 in my simplify 3d scripts for auto leveling? or rather to define the mesh grid?
                  The M557 command to define your grid area may have unreachable areas. This gets complicated because you technically don't have a z probe. So you cant really probe the bed. I would just use g28 to home the printer until you get an actual probe.
                    sleepless
                    thanks for the advise. after reading this forum i was under the impression I could keep using the original auto level style of the machine. https://forum.duet3d.com/topic/4737/zprobe-robo3d-r1
                      Yes it could auto level the x axis, but that's not the same as probing the bed.
                      sleeplessundefined 1 Reply Last reply Reply Quote 0
                        sleepless @Phaedrux
                        @phaedrux hmmm i am confused would you mind clarifying the difference for me. Sorry and thank you
                          A probe is normally attached to the print head and is movable to all areas of the bed so it can find the height of the bed across its whole surface. This can be used to get an idea of how the bed lays in relation to the print head.
                          What you have is two end stops in line with the x axis. This lets you adjust the tilt of the x axis to match the bed. But this is just a straight line between the two z motors. This lets you keep the z axis level on both sides, but that's about it.
                          Does that make sense?
                            dc42 administrators @sleepless
                            @sleepless said in Your Duet rejected the HTTP request: page not found:
                            M557 X15:215 Y15:239 S20 I was curioius if the S20 in this code from the Zprobe area in the config.g file was the number of probing points? Also how do i increase my homing speed?
                            S20 is the spacing (in mm) between probing points.
                            Homing speeds are set by the F parameter in the G1 S1 commands in the homing files; except that if you home Z using a Z probe, then you will use a G30 command to home Z and the speed is the same as for all Z probing moves, as defined by the F parameter in the M558 command.
                            sleeplessundefined 2 Replies Last reply Reply Quote 0
                              sleepless
                              But they both take multiple points from the bed to adjust for any misalignment so I guess I can see the difference in the way the do their calibrating based off those points, but in the end both styles (probe or microswitch) should go through the autolevel procedure. It seems you are saying the robo cant do this with the microswitch?
                                sleepless
                                https://www.youtube.com/watch?v=eFywzPM9lfA here is a link to the robo3d autolevel for reference
                                  sleepless @dc42
                                  @dc42 thank you.
                                    sleepless @dc42
                                    @dc42 would you mind if you have a moment looking at the config.g and bed.g file i uploaded and let me know why my I am getting a error code for autolevel when i try to print I also have a fan issue but will get to that later. I want to finish with autolevel .
                                      @dc42 would you mind if you have a moment looking at the config.g and bed.g file i uploaded and let me know why my I am getting a error code for autolevel when i try to print ...
                                      What error message are you getting?
                                        sleepless
                                        tried a test print
                                          sleepless @dc42
                                          @dc42 Error: Z probe already triggered at start of probing move
                                            sleepless
                                            https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors i think i was supposed to do this calibration not the other probe calibration i was doing?
