    Need the Duet Wifi firmware as my SD seems to be corrupted
    Firmware installation
    • crchisholmundefined
      crchisholm
      I am sure there is something in the docs to tell me, but I can't find a reference to download the firmware (whatever the current stable version is). Can someone point me in that direction?
        I presume you mean the SD card contents, not the firmware. There is a link to it from https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure.
        crchisholmundefined 1 Reply Last reply Reply Quote 0
          crchisholm @dc42
          Apparently, what ever happened the other day completely corrupted the SD card. I can't read it with anything and I can't even re-format it. Is there anything that makes it necessary to restrict the size of the SD card? Can I replace it with something larger? (smallest I have is 16gb)
            Yes you can use a larger SD card. We recommend that you format it using the largest cluster size possible, which is normally either 32kb or 64kb.
              T3P3Tony administrators @crchisholm
              @crchisholm a SDHC card is fine.
