Macro command bl touch no longer works
Is the version of DWC on the SD card in step with the firmware on your Duet?
Thank you for your reply.
I do not think because it dates from the month of JANUARY.
Or can we find the corresponding .bin file because I have the same file but it is in .ZIP
thank you -
If you had the Duet replaced but kept the old SD card, maybe you just need to update DWC.
If your Duet firmware is 1.19 or later then there is no longer a DuetWebControl.bin file. Instead the DWC files live in the /www folder of the SD card. See https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure.
That's the wrong folder. Those files and folders must be in folder /www. I think you have some old DWC files in /www instead.
