Z Probe setup for a fresh install
Hi, i did all the installation required to have bltouch running. (Im using a Tevo Little Monster)
As i powerup the printer it does its test and after it it gets his red light stable on.
Z probe on sensors is reading 0 as a value.
How can i test it to prove it is actually working?? Whats the g-code to move the pin in and out? -
Alarm Release + Pin UP
M280 P7 S160 I1 ; Alarm Release and Push-Pin UP
Pin Down
M280 P7 S10 I1 ; Send PWM channel 7 the s10 (angle) command
Pin Up
M280 P7 S90 I1 ; Send PWM channel 7 the S90 (angle) command
Self-Test
M280 P7 S120 I1; Send PWM channel 7 the S10 (angle) command -
change to P7 to P3 if using heater 3
Have you seen this? https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
