Homing Issues with CoreXY and two z-axis drivers [SOLVED]
Firmware installation
    featheryjam2
    Hi, I'm having issues with homing the z axis. It is currently plugged into drivers 2 and 4 and the leadscrews move in sync. I've got a corexy printer (dbot corexy) and am using a precision piezo probe, which seems to work (G30 works great).
    The issue I'm having is when I run homez.g (or click the home z button, or run G28 Z). I'm currently running on the 2.02 RC3 (but had the same issues with 2.01, with Duet Wifi). My homez.g is a relatively simple and I've listed it below:
    [homez.g]
    G28 X
    G28 Y
    G30
    This results in an error "G28 Z Error: Homing Failed", even though each of these commands individually works just fine.
    Any thoughts?
    Thanks
      featheryjam2
      I may have figured it out. Apparently it does not like when you do G28 X or G28 Y in the homez.g script.
      undefined 1 Reply Last reply 18 Nov 2018, 07:36 Reply Quote 0
        mikebridge
        here's my homez script for my coreXY w/ 2 Z drivers:
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool on Sat Jan 06 2018 19:43:35 GMT-0600 (Central Standard Time)
        G91 ; relative positioning
        G1 Z5 F30000 S2 ; lift Z relative to current position
        G90 ; absolute positioning
        G1 X190 Y206 F30000 ; go to first probe point
        G1 Z5 F500 ; lift Z relative to current position
        375x360x415 CoreXY DuetWifi + Duex5
        24v 600w, E3D Chimera, Zesty Nimble CC, BLTouch, X&Y linear rails, dual Z motors
          mikebridge
          also, in my config.g (I have a duex5 expansion board)
          M584 X0 Y1 Z5:6 E3:4 ; Set Drive mappings
          M671 X457:-58 Y206:206 S4 ; Define Z-Leadscrew positions
          and in my bed.g
          G28
          G30 P0 X20 Y20 Z-99999
          G30 P1 X20 Y345 Z-99999
          G30 P2 X370 Y345 Z-99999
          G30 P3 X370 Y20 Z-99999
          G30 P4 X190 Y206 Z-99999 S2
            dc42 administrators @featheryjam2
            @featheryjam2 said in Homing Issues with CoreXY and two z-axis drivers [SOLVED]:
            That's correct. You can use M98 Phomex.g and M98 Phomey.g instead if you need to. However, as you are homing Z using a G30 command, you should have the Z endstop position set to "none" in the M574 command, and in that case the firmware will not let you home Z unless X and Y have already been homed.
            5 out of 5
