WiFi security with user id [solved]
THe WiFi at the university uses a scheme with user id and password. Can i connect a duet WiFi to this type of network?
You may find that is just to get access to the internet via the wifi rather than get an IP address on the network? Try connecting to the network on your computer and pinging different local IP addresses before authenticating.
If you can't get it connected to the WiFi, there is also the option of setting the Duet to use access point mode, so that you can connect directly to the Duet.
@buj the Duet cannot authenticate on university or similar networks that prompt for a user ID and password in the browser. In this case it is best to use the Duet in access point more and has been suggested.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface
