Auto calibration error
@yatinsd, I think bed probing must have failed but the firmware didn't realise that. Is is definitely probing within the confines of the bed?
Please post your current config.g file and the bed.g file.
@dc42 0_1542626982241_bed.g 0_1542626988960_config.g , and also after sometimes it stops responding on web interface for head position manual change(this happened only after i updated the firmware first to 2.02 rc3 then to rc4 with suitable wifi server web interface versions.
Please try using S6 on the final G30 command in bed.g instead of S7. The 7-factor calibration may not work well if the calibration is a long way out to start with. Also we recommend use of either 6- or 8-factor calibration.
This happened when i tried auto calibration again to have converging results after one round of calibration.(I have shifted to 6 factor calibration)0_1542646205637_bed.g
Below is the result of first round of calibration:
Calibrated 6 factors using 16 points, deviation before 3.775 after nan
Also when it homes for auto calibration not all axis are homing only one i have to do them manually first. -
@yatinsd said in Auto calibration error:
See https://duet3d.dozuki.com/Wiki/FAQ#Section_When_I_try_to_home_my_printer_sometimes_the_carriage_or_carriages_move_only_part_of_the_way_towards_the_homing_switches_and_I_have_to_command_it_to_home_again_to_make_it_go_all_the_way. The failed homing may explain the problem.
@dc42 now it homes but still there is this probing error.
Do you get probing error messages the first time you run auto calibration? I was under the impression that you only got them the second and subsequent times that you ran it.
@dc42 i got the error only the second time, first time it ran fine with below results:
Calibrated 6 factors using 16 points, deviation before 3.775 after nan -
@yatinsd, please sort out the homing issue first - see my earlier reply. Then see whether the auto calibration problem persists.
@dc42 yes I have already sorted homing issue, but auto calibration problem is still persisting!
Does your config-override.g file have M665 and/or M666 commands in it? If so, delete them.
@dc42 there is no config override file being created after auto calibration! can this be due to the macro files that i deleted accidently?
Auto calibration does not in itself create a config-override.g file; but you can send M500 after running auto calibration to save the values.
So was there a config-override.g file on your system, or not?
@dc42 I cannot see any such file!
@dc42 I tried M500 command still the same issue the when home after 1st auto calibration the head position goes random for xyz. Though now the config override file is created.
Please can you change the S parameter on the final G30 command to S-1. This will cause the firmware to report the height errors without making any changes. Then report the height errors here.
@dc42 I did the same as you said but the problem has just dissapeared now, i dont know how( i am able to auto calibrate it one after other). But there is one peculiar thing happening that ( I deleted the config-override file before i started the auto-calibration) now when i try and pass the M500 command no config override file is generated.
@dc42 it is now showing the config override file as well!
I'm glad it's now working for you. If it goes on working, please mark this thread as Solved by editing the title.
Duet Web Control doesn't update its file lists automatically. You often need to click the Refresh button to see the latest changes. This may be why you didn't see the config-override.g file at first.
