    M122 does not work from DWC console
    Firmware installation
    1.5k
    • Adrian52undefined
      Adrian52 @dc42
      @dc42 my impression is that quite a few commands do work. I will do a more comprehensive check next time it happens
      • Adrian52undefined
        Adrian52
        I tried again today, and the output of the DWC g-code console is here:
        0_1536253098443_20180906m122 from dwc.txt
        M122 just over 1hr after the print finished did not give a response, although there was no disconnect/reconnect this time. I then tried M665, M666, head movement, homing and adjusted the hot end temperature, and listed the sd card with M20 - all seemed to work. Re trying M122 worked this time. Simply retrying M122 has not previously worked. Will check again when I get the full disconnect response to M122.
          Added to my list to look at.
          • sigxcpuundefined
            sigxcpu
            Here's a traffic capture when M122 fails on DWC (but works on serial & telnet).
            T 2018/09/08 23:46:05.963684 192.168.27.112:55398 -> 192.168.27.8:80 [AP] #47
            GET /rr_gcode?gcode=M122 HTTP/1.1.
            Host: 192.168.27.8.
            Accept-Encoding: gzip, deflate.
            Connection: keep-alive.
            Accept: application/json, text/javascript, */*; q=0.01.
            User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_0) AppleWebKit/602.2.14 (KHTML, like Gecko) Version/10.0.1 Safari/602.2.14.
            Referer: http://192.168.27.8/.
            Accept-Language: en-us.
            X-Requested-With: XMLHttpRequest.
            T 2018/09/08 23:46:05.969594 192.168.27.8:80 -> 192.168.27.112:55398 [AP] #48
            HTTP/1.1 200 OK
            Cache-Control: no-cache, no-store, must-revalidate
            Pragma: no-cache
            Expires: 0
            Access-Control-Allow-Origin: *
            Content-Type: application/json
            Content-Length: 12
            Connection: close
            {"buff":255}
              That response means that you have already sent some commands to be executed from DWC, that are waiting to be executed, and the input pipeline is full. So the M122 command has probably not completed. Perhaps you need to make more rr_reply calls to retrieve the M122 response.
              • Adrian52undefined
                Adrian52
                M122 still not working consistently from dwc using 2.02rc4/1.22.5. As before, usually works after one print, but subsequently causes no response but a brief disconnection /reconnect. M122 works from yat. Tried M122 from android app, and this also gave disconnect/reconnect response, seen simultaneously on the pc dwc.
                  How many clients are logged on to the Duet when you send M122? I'm wondering whether it could by running out of buffers if you have multiple web clients logged on.
                  Adrian52undefined 1 Reply Last reply Reply Quote 0
                  • Adrian52undefined
                    Adrian52 @dc42
                    @dc42 I get the problem with just a windows 10 pc running Firefox connected. Incidentally, only M122 seems to be affected - I can continue printing with no obvious problems.
                    • chrishammundefined
                      chrishamm administrators
                      I have never seen this for a particular code like M122. But there is a known issue that occurs when you run two or more instance of DWC on the same device/IP: In this case only one of the DWC instances will actually receive the G-code reply and the others will just print an empty/successful response. Please verify this again.
                      Duet software engineer
                      • Adrian52undefined
                        Adrian52 @chrishamm
                        @chrishamm I have uninstalled 'find my duet' from my phone, and the only instance of dwc I have running is on my win10/Firefox pc. Still get the same problem - there is a 10 second pause after sending M122, then a disconnect /reconnect. Just trying another print without rebooting the duet.
                        • Adrian52undefined
                          Adrian52 @Adrian52
                          @adrian52 Print completed fine. M122 from YAT gave this . M122 from DWC gave
                          The earlier two disconnects were responses to M122 before the print.
