    Make use of variables
    Firmware wishlist
    14
    40
    6.7k
    • garyd9undefined
      garyd9 @dc42
      @dc42 said in Make use of variables:
      I anticipate that the new features would be used almost exclusively in macro files that are used only on printers running RepRapFirmware.
      Then perhaps call it something else (RRF-Code or Duet-Code) with a different file extension and only allow it in macros. I realize that you have a certain expectation of competence of your users, but there's a large potential for something to go wrong when these machines are being used for laser cutters, CNC, etc
      fmaundefined 1 Reply Last reply Reply Quote 0
      • Googliolaundefined
        Googliola @dc42
        @dc42 From a user perspective, the terminology would cause confusion and additional and maintained documentation , but then the question is how much you weigh user-friendliness.
        If I were in your shoes, I would probably stick to ease and coherence with known / documented guidelines. You might open Pandora box here. People might argue that common (Fanuc) standards are 'better'. Comes down to taste at the end of the day really...
        • botundefined
          bot
          I really like your proposal, dc42.
          I have only one immediate use-case that I would want to employ: check current z height, and raise then lower bed to switch IDEX tools and avoid obstacles near the bed perimeter, if current z height is insufficient to clear said obstacles. This would have to be located in the actual print gcode files, in the tool switching script.
          I don't see any problem with doing this, based on your proposal, but just wanted to mention a use-case that would have the script inside a gcode file for printing.
          edit: Upon further reflection, these commands could be contained in the firmware-based macro tool change scripts. I was thinking of a case of using slicer based tool change scripts, but that would not be necessary. Ignore my stated use case of scripts in a printable gcode file.
          *not actually a robot
            Googliola
            @dc42 Haven't had much time lately to follow up on my feature request. With holidays ahead, this will change soon 🕺 🤞
            Just been wondering how the object model is coming along and if you could make a statement about when / what version it will be implemented.
            Thanks in advance
              dc42 administrators @Googliola
              @googliola said in Make use of variables:
              Thanks in advance
              A small amount of the object model is supported in firmware 2.02RC5 along with variable substitution, as a proof of concept. The full implementation is planned for release 2.03.
              • fmaundefined
                fma @garyd9
                @garyd9 said in Make use of variables:
                Didn't follow this thread before... I agree with @garyd9: as no slicer will generate such custom G-Code, if the goal is to use it from macros, I suggest to write a macro language, like Slic3r does, evaluated by the macro pre-processor, and keep a standard G-Code.
                Frédéric
                  The additional facilities will be provided by way of additional (not replacement) syntax and will not affect the ability of RRF to run GCode produced by slicers.
                  • fmaundefined
                    fma
                    Yes, I understand, but this means that it will be possible to use this syntax from Slicers (using custom code), which is, IMO, more dangerous than from macros only...
                    Frédéric
                    • fmaundefined
                      fma
                      Maybe another thing to think about is having the possibility to give params to macros...
                      Frédéric
                        dc42 administrators @fma
                        @fma said in Make use of variables:
                        Yes, I will probably include that.
                        • Ringo1508undefined
                          Ringo1508
                          Glad I found this topic! Sorry for dragging up an old topic but I don't see any other information on the wiki about this.
                          I'm looking for variable support as well. An example of an immediate want (notice I didn't say need lol) is the ability to call a macro with hotend first layer temperature and bed temperature parameters.
                          My Cartesian machines all will set initial hotend temp to 160° while bed heats up, then do a mesh bed leveling and finally heating up the nozzle to print temp just outside the print area and doing a purge line before it begins the print.
                          Yes I know that I can put this in Slic3r custom gcode for print start, but then I have to manage it for each printer 😁 I'd love to take advantage of just putting the macro call in the custom gcode section.
