Please Help.. Homing Z
    TOFUATSU
    I am almost don building my first printer. I have a CoreXY. I am using a Duet WiFi (original), DC42 ir sensor. I have the X and Y moving correctly and finding home.
    no matter if I use the home all or do one axis at a time. I always get the same G28 Error: G0/G1: insufficient axes homed.
    the Y endstop is located at the front left. the x endstop is on the left of the x carriage. the z probe is right by the hotend.
    here is my config file
    ; generated by RepRapFirmware Configuration Tool v2 on Sun Dec 16 2018 19:19:32 GMT-0500 (Eastern Standard Time)
    M667 S1 ; Select CoreXY mode
    M550 P"My Printer" ; Set machine name
    M552 S1 ; Enable network
    ;*** Access point is configured manually via M587
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P3 S0 ; Drive 3 goes backwards
    M92 X80.00 Y80.00 Z1600.00 E418.60 ; Set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
    M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z380 S0 ; Set axis maxima
    M574 X1 Y1 S0 ; Set active low and disabled endstops
    M574 Z1(I tried Z0 and Z2 here also
    ) S2 ; Set endstops controlled by probe
    M558 P1 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
    G31 P500 X0 Y0 Z3 ; Set Z probe trigger value, offset and trigger height
    M557 X15:195 Y15:195 S20 ; Define mesh grid
    M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    M501 ; Load saved parameters from non-volatile memory
    T0 ; Select first tool
    undefined 1 Reply Last reply 17 Dec 2018, 01:25 Reply Quote 0
      Stephen6309 @TOFUATSU
      @tofuatsu You need to ads a S1 to all axis moves that are done before homing. For example: G1 Z5 S1 F3000
      undefined 1 Reply Last reply 17 Dec 2018, 01:41 Reply Quote 0
        TOFUATSU @Stephen6309
        @stephen6309
        Please forgive me.. I am really new. I looked into it.. are you talking about adding S1 command in the homeall.g file? I think they are present. This is my file
        ; homeall.g
        ; called to home all axes
        G91 ; relative positioning
        G1 S1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
        G1 S1 X-305 ; home X axis
        G1 S1 Y-305 ; home Y axis
        G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
        G1 S1 Y-305 ; then move slowly to Y axis endstop
        G90 ; absolute positioning
        G1 X15 Y15 F6000 ; go to first bed probe point and home Z
        ;G91 ; relative positioning
        ;G1 S2 Z5 F100 ; lift Z relative to current position
        ;G90 ; absolute positioning
        undefined 1 Reply Last reply 17 Dec 2018, 01:48 Reply Quote 0
          @tofuatsu I finally got around to upgrading my corexy with the presale DuetWifi from 1.18 to 2.02RC6 and had to change my homing files.
          My homeall.g:
          ; generated by RepRapFirmware Configuration Tool on Thu Oct 06 2016 12:46:23 GMT-0400 (Eastern Daylight Time)
          ; Relative positioning
          G91
          ; Lift Z
          G1 Z5 S1 F9000
          ; Move towards X and Y axis endstops (first pass)
          G1 X-405 F3000 S1
          G1 Y-305 F3000 S1
          ; Go back a few mm
          G1 X5 Y5 F9000
          ; Move slowly to axis endstops once more (second pass)
          G1 X-405 F360 S1
          G1 Y-305 F360 S1
          ; Absolute positioning
          G90
          ; home the Z axis
          G1 X200 Y150 F9000
          G30
          undefined 1 Reply Last reply 17 Dec 2018, 02:44 Reply Quote 0
            @stephen6309 hummm I copy and pasted your homeall file... it still fails when it tries to home the bed. to does move differently.
            undefined 1 Reply Last reply 17 Dec 2018, 13:52 Reply Quote 0
              dc42 administrators @TOFUATSU
              @tofuatsu said in Please Help.. Homing Z:
              Check that there are no commands in your deployprobe.g and retractprobe.g files, unless you are using a BLTouch - in which case, check that they are the correct commands.
              undefined 1 Reply Last reply 17 Dec 2018, 23:54 Reply Quote 0
                TOFUATSU @dc42
                @dc42 Thank you so much!!! That was it!!
                7 out of 7
