    Problems with adapting Duet to 3D Kreator Motion 3D printer
    1.5k
    • DocTruckerundefined
      DocTrucker
      There was a three pin fan voltage selector on the Duet Ethernet I had a few months back. Look at the wiring schematic and you'll be able to remove the jumper and feed one of these pins with the voltage you require.
        Test the axes by jogging them before you attempt homing. You can send M564 H0 to allow them to be jogged before they have been homed.
        Regarding the fans, see https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V. Or buy 24V fans, they don't cost much.
        • ov_darknessundefined
          ov_darkness
          Ok, I'll buy new fans 🙂
          Jogging works ok.
          Sould the endstop light be off when triggered or on? Mine are constantly lit, and going off whe they're triggered. I've tried to flip tem in configurator tool, and they're stil not working.
          Is there any additional steps to enable sensorless homing apart from setting this in config?
          Pro level AM audit, support and sales.
          Management of 3D scanning and printing services.
          Focused on Central and Eastern Europe.
            ov_darkness
            Homing is not working.
            No matter if I set NO or NC, or use stall detection. It just keeps banging head against the frame
            Ok, I have this sorted: my printer now homes perfectly!
            @dc42 Another question:
            Is there a way to use Z sensor that close circuit between bed and nozzle on specific points ( 4 corners and in the middle of front and back)?
            Old board had this semi-automatic bed leveling, where it was positioning itself over the corners of the build plate and flashed RGBW LED's when nozzle was touching the bed.
            It would be nice to have this in Duet, also, is there a way to control RGB LED's?
              dc42 administrators @ov_darkness
              @ov_darkness said in Problems with adapting Duet to 3D Kreator Motion 3D printer:
              That's normal if you are using NC switches, which is the recommended way of using microswitches. Use S1 in the M574 command in config.g. That's S1 in the M574 command in config.g.
              Test the endstops as described at https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches.
              Yes, that's possible. connect the two contacts to the two outer pins of the E0 endstop input. In your M558 command select mode 4 (P4) and also use the I1 parameter.
                ov_darkness
                I've found a while to work on this project, but documentation is somewhat unclear to me and I don;t want to damage my Duet.
                If I read this right I need to remove V_FAN jumper, then connect DC-DC converter IN to always on fan output (so I lose one out).
                then I need to connect DC-DC V_OUT to middle pin of V_FAN and leave the GND_OUT unconnected as this is common negative?
                Can I use 24V out from my PSU instead of always on Fan?
                  Yes, in fact that's the correct way to do it.
                    ov_darkness
                    Printer works as expected 🙂
                    Thank you for your help @dc42
                    Soon I'll be putting together much bigger and faster machine with Duet.
                    It'll be heated chamber COREXY.
                      ov_darkness
                      I have problems using G32.
                      I keep gettion [code]G32
                      Error: G29: No valid grid defined for bed probing[/code]
                      My bed.g file looks like that:
                      [code]
                      ; bed.g
                      ; generated by RepRapFirmware Configuration Tool on Sun Nov 25 2018 14:50:03 GMT+0100 (czas środkowoeuropejski standardowy)
                      G28 ; home all axes
                      G90 ; Back to absolute positioning
                      ; Probe the bed at 6 points
                      G30 P0 X2 Y1 H0 Z-99999
                      G30 P1 X100 Y1 H0 Z-99999
                      G30 P2 X195 Y1 H0 z-99999
                      G30 P3 X195 Y195 H0 Z-99999
                      G30 P4 X100 Y195 H0 Z-99999
                      G30 P5 X2 Y195 H0 Z-99999
                      G29 S0 ;Probe the bed and save height map to file
                      M374 ; Save calibration data. Default is sys/heightmap.csv
                      [/code]
                      and my heightmap.csv is empty.
                        Do you have an m557 command in config.g to define your grid to probe?
                          Your bed.g file probes 6 point, then does nothing with that probing and runs G29 instead. Was it really generated exactly like that by the online configuration tool? If so then we need to get that fixed.
                          I suggest you edit bed.g to contain just this command:
                          and add a M557 grid definition to config.g. See https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation.
                            ov_darkness
                            @dc42 no, it was edited by me.
                            I have M557 defined in Config.g
                              If you already have a M557 command in config.g and you are getting the "No valid grid defined" message, then that M557 command failed. Try sending exactly the same M557 command from the GCode Console to see what the error is.
