    Precision Piezo Andromeda
    Third-party add-ons
    3.7k
    • Moriquendiundefined
      Moriquendi @mikebridge
      @mikebridge The sensor responds to changes in pressure rather than total pressure. It makes no difference whether the change in pressure is positive or negative except that the polarity of the signal is inverted so you plug the Andromeda in the other way around.
      Idris
      mikebridgeundefined 1 Reply Last reply Reply Quote 0
      • SupraGuyundefined
        SupraGuy
        Or flip the board over. So long as the wingnut isn't shorting out circuitry, that is.
        Lead screw driven printer, powered by Duet 2 Wifi
        MPCNC powered by Duet 2 Wifi
        CoreXY printer driven by Duet 3 6HC
        LowRider CNC powered by Duet 2 Wifi
        Moriquendiundefined 1 Reply Last reply Reply Quote 0
          Moriquendi @SupraGuy
          @supraguy Oh yeah... that's a much better idea 👍
          • mikebridgeundefined
            mikebridge @Moriquendi
            @moriquendi phenomenal. How do they deal with low temperatures? Moved my coreXY into the garage to start getting the baby's future room ready and dc42's IR probe doesn't seem to like the near freezing temperatures with the PEI surface.
            375x360x415 CoreXY DuetWifi + Duex5
            24v 600w, E3D Chimera, Zesty Nimble CC, BLTouch, X&Y linear rails, dual Z motors
            dc42undefined A Former User? Moriquendiundefined 3 Replies Last reply Reply Quote 0
              dc42 administrators @mikebridge
              @mikebridge said in Precision Piezo Andromeda:
              ...dc42's IR probe doesn't seem to like the near freezing temperatures with the PEI surface
              That's probably because you are getting condensation on the surface, coupled with the fact that PEI is transparent to IR. Wiping the surface first to remove condensation may help. However, a piezo offers potentially better probing accuracy then the IR sensor can give using PEI as the target.
                A Former User @mikebridge
                Sorry I cant resist, If I ever needed a reminder why i have a cat this is it.... good luck with the printer in the cold environment, maybe a heater will help.
                  mikebridge @A Former User
                  @calvinx oh, we have cats too (thus why all our 3d printers have enclosures), and I told my wife I have a rule of "we can't have more pets than persons living in the house", but she's pregnant now, so we're up to 3 cats and she keeps mentioning wanting a dog too...
                  @dc42 it was triggering fine against the PEI indoors (the back of the PEI is painted w/ high-temp black paint), and there's no noticeable condensation on the surface, similar error when the bed is cold or hot. perhaps something shifted when it was moved to the garage, I'll check that today.
                    @mikebridge
                    Piezo sensors have no issues with the kind of temperatures you're likely to encounter in a garage. What you do have to be aware of is that the responsiveness does change with temperature. If you tune the system when everything's cold and then probe when it's been sitting with a hot bed for long enough for for the piezos to warm up you may see different results.
                    Idris
                    PS, Dogs are persons, just FYI.
                    • SupraGuyundefined
                      SupraGuy
                      My experience is this:
                      The piezo sensors like consistent temperatures. A change of more than about 10 deg C up or down will change how the system responds. It's getting cold here, and with the drop in temperature, I find that I need to use a space heater to keep the temperature around the printer more consistent in order not to need to make adjustments, which I'd rather avoid. My printer is in the attic, and in the summer, it's mid to upper 20s up there. In the winter, it's in the middle teens, and my last print I had my first false trigger with the Andromeda. I turned on a space heater and re-started everything when it got to 22 degrees up there, and everything was great. I assume that I could have readjusted the trigger threshhold on the board, but I want to avoid making those adjustments if at all possible. Besides, cooler air temperatures are likely to change the printing characteristics of the extruded plastic, too, so keeping a consistent temperature for use is a good thing.
                      If your printer is enclosed, and you are keeping a consistent temperature for printing anyway, I can say that I have noticed no ill effects from the Andromeda boards being stored in low temperatures, but I think the coldest that I might have tried to use it would be maybe 14°C
                        mikebridge @dc42
                        @dc42 turns out the glass cracked under the PEI sheet and that was causing the inconsistent readings. replaced w/ a geckotek spring steel build plate (see my other thread on the high temp magnetic sheet if people want more info) and my readings are very consistent now.
