    Fallback procedure #3 = DuetWifiServen.bin not found
    Firmware installation
    908
    • CozyPundefined
      CozyP
      Out of a sudden, my new motherboard stopped connecting to the wifi. I had installed the latest firmware prior this happening.
      I tried to connect the motherboard to the PC, nothing happened.
      It turns out the SDcard failed, I tried connecting the card to PC, nothing appeared, so I spent 9€ and got me a new one.
      Now, I followed every step on Fallback Procedure #3, I downloaded SamBa,
      downloaded DuetCombinedFirmware 2.02 version, send the file to SD card via SamBa.
      Then I open YAT, hit M997 S1 command and get
      M997: File DuetWiFiServer.bin not found.
      Am I missing something here???
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @CozyP
        @cozyp DuetWiFiServer.bin is not in DuetCombinedFirmware.bin. It's further down this page: https://github.com/dc42/RepRapFirmware/releases
        • CozyPundefined
          CozyP
          Okay. I grabbed the DuetWifiServer.bin file from an earlier version, removed the version and renamed it as DuetWifiServer.bin. The same error occurs.
          I tried installing an earlier version 2.01 and 2.00. Sent the CombinedFirmare.bin via SamBa, reset the motherboard, insert SD card, copy DuetWifiServer.bin file ( if the file name was had the version name, I deleted it and renamed it exactly as it is supposed to be ). I put SD card back, reset, YAT, hit M997 S1, same....
          Faulty motherboard???
            dc42 administrators @CozyP
            @cozyp, the DuetWiFiServer.bin file needs to be in the /sys folder.
            • CozyPundefined
              CozyP
              The SD card does not have any folders, even after I send the Firmware via the SamBa. Do I need to create folders???
              • CozyPundefined
                CozyP
                I am currently stuck. On the fallback procedure it doesn't mention anything regarding SD configuration..... It just says hit erase button, use Samba and YAT to command.....
                • CozyPundefined
                  CozyP
                  OK. I downloaded the entire ZIP file from latest firmware.
                  Extracted the SD image folder to SD card.
                  I renamed an the folder sys - Fisher to sys.
                  Copy - Pasted the Combined2Firmware and DuetWifiServer.bin.
                  Hit M115, firmware installed.
                  Hit M997 S1, ''not found''
                    If you send M20, does it report that the SD card is mounted?
                    If you send M503, does it echo the config.g file in /sys?
                    • CozyPundefined
                      CozyP
                      Magically, I changed the USB port into another one, repeated the procedure and it worked.
                      I will never understand electronics.....
                      Thank you for your replies DC42!!!! Will create another post on bed leveling piezo issue I was having. Hopefully, I will solve that as well!!!!
