Failed to load height map
1.2k
    hyppo
    k what could b the reason for this error?
    Error: G29: Failed to load height map from file heightmap.csv: invalid grid
    i dont have probe yet on my delta so im using the manual leveling, and trying to save to height map so i dont have to constantly do it, but im getting error massage, what cud b the prob
      It doesn't seem to like what ever you have configured in your M557 grid layout command.
      If you send M557 in the console what does it return?
        hyppo
        grid not defined
        undefined 1 Reply Last reply 20 Dec 2018, 22:46 Reply Quote 0
          hyppo
          ok the how do i save grid in correctly
            https://duet3d.dozuki.com/Wiki/GCode#Section_M557_Set_Z_probe_point_or_define_probing_grid
            https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
              dc42 administrators @hyppo
              @hyppo said in Failed to load height map:
              grid not defined
              You must have defined a grid using M557 before you did the manual mesh probing. Put that same M557 command in config.g.
                hyppo
                here to i add the g29 s0 after probing or b4?
                7 out of 7
