    Firmware 2.02 released!
    Firmware installation
    23
    70
    12.2k
    • kazolarundefined
      kazolar @Edgars Batna
      @edgars-batna I'm having similar symptoms that after it gets into some confused state, uploads slow down drastically normally at 450-600kbps, then they plumin to 160-180k, so it seems it has something better to do. There seem to be other glitches, so I went back rc5
      • kazolarundefined
        kazolar @hurzhurz
        @hurzhurz m119 was showing not triggered for me and led was working, end stops on the duet proper were ok, just appear to not work with end stops on the expansion which for me starts with my 2nd gantry - w axis. I tried bridging the wires by had remocing the plug, only reboot cleared it..
        • LeonMFundefined
          LeonMF
          I'm having weird homing behavior related to dual limit switches with 2.02. Though, I reverted to rc5 and the problem was still there.
          https://forum.duet3d.com/topic/8307/dual-z-homing-weird-behavior-on-u-limit-first/7
          Current: Railcore II ZLT w/Duet 3 and Hemera hot end.
          Retired: Robo3D R1,BI V2.5 Delta updated to BerryBot magnets, bespoke carriages and Duet Ethernet, M3D Promega;
          kazolarundefined 1 Reply Last reply Reply Quote 0
          • kazolarundefined
            kazolar @LeonMF
            @leonmf I replied on that thread -- hope that helps you, dual (or more ) z homing works fine in RC5 -- I believe there are some transient issues in 2.02 final -- possibly started with RC7 -- I notice that after a long period of on time there is some issue that builds up which results in a few other oddities, @dc42 -- i.e I noticed a slow down behavior between moves -- for example it moves, then thinks then moves again, the move is not slow (I've see that before), but it thinks a good bit before the next move -- in that state is when it starts to lose end stop triggers.
            • kazolarundefined
              kazolar
              David, I am running rc5 and after over 20 hours of printing, no issues with end stops, it's a 30 hour print, but I just checked the diagnostic page while it's printing and checked the end stops on the duex5 and they work fine. Definitely there was an issue with the new firmware and duex5 end stops.
              • LeonMFundefined
                LeonMF
                I think the U Axis homing I'm seeing is not 2.02 final specific (even though I believe it to be a real bug).
                I'm also seeing a new thing in 2.02 where the first move of any axis after homing any axis is exceptionally slow and ignores the FXXXX parameter. Subsequent moves are fine, though.
                  dc42 administrators @kazolar
                  @kazolar said in Firmware 2.02 released!:
                  That sort of slow down is usually the result of I2C communication between the Duet and the DueX breaking down. Please check the I2C stats in the M122 report when this happens. The usual cause is a poor ground connection between the VIN terminal blocks of the Duet and the DueX.
                    If/when this happens again, after the print finishes please check:
                    • The I2C stats in the M122 report
                    • If you have any fans connected to the DueX then test whether they are still working.
                    • kazolarundefined
                      kazolar @dc42
                      @dc42 David, this never happens with rc5, how can it be hardware/wiring related. I'm running rc5 now and haven't had it happen in over 100 hours of printing.
                        Whatever the reason for the problem, I need the results of the tests I requested, to determine whether the I2C comms have stopped working or just the endstops on the DueX5.
                        • kazolarundefined
                          kazolar
                          @dc42 I have a long print project to complete, so I won't be able to roll back to 2.02 final until after it's done. I am in hour 10 of a 2nd 30 hour print, then I have 3 12 hour parts to print out. I can test it on a benchy this weekend -- it is absolutely repeatable after 4+ hours of printing. BTW when it happened I did electrical testing the duet and duex5 -- I tested the 5v, 3.3v and 24v rails for any variants -- and everything was copacetic, my first thought it was wiring related, but everything checked out fine, and since a rollback to rc5 fixed it, I'm sure it's not.
                          BTW, i have 2 fans blowing across the duet and they're working fine -- duet MCU reports 25-26c even during 20+ hour long print jobs
                          • bret4undefined
                            bret4
                            Just wanted to say the new firmware is working fine on my Hypercube Evolution. Only problem I found was that I had to make changes to my config.g to get it to work after upgrading. 2.01 I believe was my old firmware. Now with 2.02 I had to make these changes to config.g to get it to work.
                            Old settings:
                            M208 X0 Y0 Z0:0 U0 S1 ; Set axis minimum
                            M208 X285 Y270 Z285:285 U285 S0 ; Set axis max
                            New Settings:
                            M208 X0 Y0 Z0 S1 ; Set axis minimum
                            M208 X285 Y270 Z285 S0 ; Set axis max
                            What would happen is it would set my Z axis Min and Max to 285mm with the old settings. This would always move the bed to the furthest position from the head and start printing in air. Not on the bed. Those old settings worked fine in the old version but mess things up bad in the latest firmware. Spent about 10 hours trying to figure out this problem.
                            Hope this is of some help to others that may have problems with Z axis moving strange after upgrading.
                              I'm glad you got it working. The reason you had problems was that firmware 2.01 ignored the second Z value in your M208 command, whereas firmware 2.02 allows you to use e.g. M208 X0:200 Y-10:200 Z0:250 instead of using separate M208 S0 and M208 S1 commands.
                              • mveinotundefined
                                mveinot
                                Hi all, been using Duet3D for my CoreXY since the middle of last year or so.
                                Since 2.02 I've been unable to home the axes correctly. I use stepper resistance to home the X/Y and a BLTouch to home Z (I assume this is probably still working)
                                After updating to 2.02 I got a message when I try to home about insufficient axes being homed - did some reading and saw I needed to add M564 H0 to allow movement before the axes were homed, so I did that, but now the print head just smashes into the 0 position and tries to keep going instead of determining that's the home position and proceeding with the rest of the home position.
                                I've placed my config and home gcode files at this location.
                                Any help would be greatly appreciated.
                                • wilrikerundefined
                                  wilriker @mveinot
                                  @mveinot First of all I would not recommend the use of M564 H0. This opens up a possibility for bad things IMHO. You should always adapt your homing macros as a better solution (and home before any movement).
                                  I was looking at your homex.g (and homey.g) and at least they should not create this error message. Maybe your homeall.g does. Only thing that I found a little strange in your homex.g is that you go to home, go to X=5 and at the end set this position to be 0 via G92 X0. This might be totally correct for your setup but I find it quite strange. (I also find you regular acceleration values of 15,000mm/s² strange but again this might be totally fine for your machine)
                                  Anyway, regarding the stallGuard-based homing I sadly cannot really help since I don't use it. The only thing I can think of is that something changed (mechanically, inside firmware) and your previous stallGuard settings just don't work anymore, i.e. it does not detect the stall.
                                  Manuel
                                  My Tool Collection
                                  mveinotundefined 1 Reply Last reply Reply Quote 0
                                  • mveinotundefined
                                    mveinot @wilriker
                                    @wilriker Thanks for the insights. The reason I set the x=5 offset is that the x/y carriage bumps into part of the printer frame if I don't move it in a bit on that axis.
                                    Even trying to home each axis individually I was still getting that error (insufficient axes homed)
                                    My homeall.g just calls each of the individual homing files in sequence, it doesn't do anything special.
                                    • wilrikerundefined
                                      wilriker @mveinot
                                      @mveinot Oh wait, you have M452 in your config.g. This sets your printer into Laser mode. In this case it is mandatory to change all your G1 Snnn into G1 Hnnn. This is because in 2.02 when the printer is set to laser mode the Snnn parameter of G1 controls the laser power!
                                      From the documentation of M452
                                      Very important! If you use M452 to put your machine into Laser mode and are running Firmware 2.02 or above, you must replace all S parameters in G0/G1 commands in homing files etc. by H parameters. This is because S is now used to control laser power.
                                      Manuel
                                      My Tool Collection
                                      • mveinotundefined
                                        mveinot @wilriker
                                        @wilriker Darnit! I forgot all about having that in there. Yep, that did it. Thank you so much.
                                          dc42 administrators @mveinot
                                          @mveinot, you can avoid the move to X5 and G92 X0 if you change the M208 lower X limit from 0 to -5.
                                          • mveinotundefined
                                            mveinot @dc42
                                            @dc42 Thanks, I've made that change as well. Seems to work!
