    Firmware 2.02 released!
    Firmware installation
    23
    70
    12.2k
      I'm glad you got it working. The reason you had problems was that firmware 2.01 ignored the second Z value in your M208 command, whereas firmware 2.02 allows you to use e.g. M208 X0:200 Y-10:200 Z0:250 instead of using separate M208 S0 and M208 S1 commands.
      • mveinotundefined
        mveinot
        Hi all, been using Duet3D for my CoreXY since the middle of last year or so.
        Since 2.02 I've been unable to home the axes correctly. I use stepper resistance to home the X/Y and a BLTouch to home Z (I assume this is probably still working)
        After updating to 2.02 I got a message when I try to home about insufficient axes being homed - did some reading and saw I needed to add M564 H0 to allow movement before the axes were homed, so I did that, but now the print head just smashes into the 0 position and tries to keep going instead of determining that's the home position and proceeding with the rest of the home position.
        I've placed my config and home gcode files at this location.
        Any help would be greatly appreciated.
        • wilrikerundefined
          wilriker @mveinot
          @mveinot First of all I would not recommend the use of M564 H0. This opens up a possibility for bad things IMHO. You should always adapt your homing macros as a better solution (and home before any movement).
          I was looking at your homex.g (and homey.g) and at least they should not create this error message. Maybe your homeall.g does. Only thing that I found a little strange in your homex.g is that you go to home, go to X=5 and at the end set this position to be 0 via G92 X0. This might be totally correct for your setup but I find it quite strange. (I also find you regular acceleration values of 15,000mm/s² strange but again this might be totally fine for your machine)
          Anyway, regarding the stallGuard-based homing I sadly cannot really help since I don't use it. The only thing I can think of is that something changed (mechanically, inside firmware) and your previous stallGuard settings just don't work anymore, i.e. it does not detect the stall.
          Manuel
          My Tool Collection
          mveinotundefined 1 Reply Last reply Reply Quote 0
          • mveinotundefined
            mveinot @wilriker
            @wilriker Thanks for the insights. The reason I set the x=5 offset is that the x/y carriage bumps into part of the printer frame if I don't move it in a bit on that axis.
            Even trying to home each axis individually I was still getting that error (insufficient axes homed)
            My homeall.g just calls each of the individual homing files in sequence, it doesn't do anything special.
            • wilrikerundefined
              wilriker @mveinot
              @mveinot Oh wait, you have M452 in your config.g. This sets your printer into Laser mode. In this case it is mandatory to change all your G1 Snnn into G1 Hnnn. This is because in 2.02 when the printer is set to laser mode the Snnn parameter of G1 controls the laser power!
              From the documentation of M452
              Very important! If you use M452 to put your machine into Laser mode and are running Firmware 2.02 or above, you must replace all S parameters in G0/G1 commands in homing files etc. by H parameters. This is because S is now used to control laser power.
              Manuel
              My Tool Collection
              • mveinotundefined
                mveinot @wilriker
                @wilriker Darnit! I forgot all about having that in there. Yep, that did it. Thank you so much.
                  dc42 administrators @mveinot
                  @mveinot, you can avoid the move to X5 and G92 X0 if you change the M208 lower X limit from 0 to -5.
                  • mveinotundefined
                    mveinot @dc42
                    @dc42 Thanks, I've made that change as well. Seems to work!
                    • Hornetriderundefined
                      Hornetrider
                      Hi Guys,
                      I hope you can help me out.
                      I have updated to latest FW2.02 and DWC2.0.0-RC3 and at first it looked great.
                      But since the update I can't home my axes, any of it. I tried to modify the home files, f.e. homex.g with very slow movement but that didn't help.
                      I allways receive the error G0/G1:insufficient axes homed
                      I checked the switch states again and they work fine.
                      It seems like S1 is ignored...
                      Here the config.g:
                      M550 P"RicDuet" ; Set machine name
                      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      M569 P0 S0 ; Drive 0 goes backwards
                      M569 P1 S0 ; Drive 1 goes backwards
                      M569 P3 S0 ; Drive 3 goes backwards
                      M350 X32 Y32 Z32 E32 I0 ; Configure microstepping without interpolation
                      M92 X160.00 Y160.00 Z8000.00 E210.02 ; Set steps per mm
                      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X10020.00 Y10020.00 Z198.00 E10020.00 ; Set maximum speeds (mm/min)
                      M201 X1000.00 Y1000.00 Z100.00 E3000.00 ; Set accelerations (mm/s^2)
                      M906 X1200.00 Y1200.00 Z1200.00 E1200.00 I0 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S0 ; Set idle timeout
                      M208 X210 Y297 Z220 S0 ; Set axis maxima
                      M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                      M574 Z1 S2 ; Set endstops controlled by probe
                      M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
                      G31 P500 X0 Y0 Z0.750 ; Set Z probe trigger value, offset and trigger height
                      M557 X5:170 Y5:275 S20 ; Define mesh grid
                      M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M563 P0 D0 H1 ; Define tool 0
                      T0 ; Select first tool
                      and f.e. homex.g
                      ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 31 2018 02:05:14 GMT+0100 (Mitteleuropäische Normalzeit)
                      G91 ; relative positioning
                      ;G1 Z5 F6000 S2 ; lift Z relative to current position
                      G1 S1 X-215 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 X6 F6000 ; go back a few mm
                      G1 S1 X-215 F100 ; move slowly to X axis endstop once more (second pass)
                      ;G1 Z-5 F6000 S2 ; lower Z again
                      G90 ; absolute positioning
                      Just unmarked the Z axis movents not to be anoyed...
                      Any ideas?
                      BR
                      Ric
                        Phaedrux Moderator @Hornetrider
                        @hornetrider Can you post your other homing files? Homex looks correct.
                        Hornetriderundefined 1 Reply Last reply Reply Quote 0
                          Hornetrider
                          @Phaedrux
                          thanks for the quick reply.
                          The homeall.g looks similar to the homex.g as it was generated with the RepRapFirmware Config Tool.
                          It uses the same controls just for all axes and including the G30 for the Z Probing.
                          The strange thing is, before the FW update (done 02.01.19) the homing worked fine...
                          Also
                          G1 S1 X-215 F1800
                          work fine as the X-Axe goes back the distance after hitting the first time the switch....
                          But at the end of the script the error message appears.
                            Hornetrider @Phaedrux
                            @phaedrux
                            pls see bellow
                            G1 S1 X-215 Y-302 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                            G1 S1 X-215 Y-302 F360 ; move slowly to X and Y axis endstops once more (second pass)
                            G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                            ;G91 ; relative positioning
                            ;G1 S2 Z5 F100 ; lift Z relative to current position
                            ;G90 ; absolute positioning
                            Tried also to replace the Sx by Hx and it didn't help other than generating an error message less precise then the G0/G1
                            This is kind of anyoing.
                            BTW
                            in the SYS Folder, what files should be there.
                            After Update I have far more there...
                            1_1546604947364_Sys files_2,20190104.PNG 0_1546604947161_Sys files_1,20190104.PNG
                            • wilrikerundefined
                              wilriker @Hornetrider
                              @hornetrider Your homeall.g looks OK to me. Though I don't use G30 in my setup so not sure if there is anything needed to adjust.
                              Regarding the amount of files in /sys: the new simplified update with just on ZIP file contains all the various update files for Duet Wifi, Ethernet and Maestro. This will add some files to your /sys folder that you don't need but they don't do any harm either.
                              Manuel
                              My Tool Collection
                                Hornetrider @wilriker
                                @wilriker
                                thx.
                                Did you have a Cartesian Style Printer?
                                Have you had to change any commands after update?
                                I am going crazy...and most likely it is something tiny...like allways...arghhh
                                • wilrikerundefined
                                  @hornetrider Yes, I do have a Cartesian printer and since I follow along all Beta/RC versions and usually immediately adapt to all introduced changes I did not have to adjust anything special here.
                                  Here's my homeall.g for comparison:
                                  ; homeall.g
                                  ; called to home all axes
                                  ; generated by RepRapFirmware Configuration Tool on Sat Apr 28 2018 20:07:26 GMT+0200 (CEST)
                                  G1 H2 Z2 F3000          ; lift Z relative to current position
                                  ; X and Y
                                  G1 H1 X-300 Y-300 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
                                  G1 X5 Y5 F3000          ; go back a few mm
                                  G1 H1 X-300 Y-300 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                  ; Z
                                  G1 H1 Z-300 F900        ; move quickly to Z axis endstop and stop there (first pass)
                                  G1 Z2 F3000             ; go back a few mm
                                  G1 H1 Z-300 F180        ; move slowly to Z axis endstop once more (second pass)
                                  Manuel
                                  My Tool Collection
                                    @wilriker
                                    HI Manuel
                                    just used your setup and it didn't work....
                                    It seems to stop right after x/y hit the first time the limit switch...
                                    Ric
                                      I think the problem may be the I0 in M906 and the S0 in M84. My guess is that this sets the motor currents to zero immediately after the homing move stops, and that is flagging the axes as not homed again.
                                        Hornetrider @dc42
                                        You are a genius!
                                        After setting I0 in M906 to I0.1 it works fine again!
                                        Thank you very much!
                                        • BPisLifeundefined
                                          BPisLife
                                          @dc42 thanks for incorporating my feedback on the latest PanelDue firmware with both the Stop button taking priority and actually stopping the printer immediately as well as the 2mm/s federate on the extruder.
                                          Really liking the notification system on the latest firmware! Nice work to everyone involved.
                                          • joestefanoundefined
                                            joestefano
                                            David, I am having trouble with Z height reliability. I am using your Z IR probe, I have a slightly tinted glass heat bed approx. 6mm thick. I have placed a piece of black paper under the glass at my home location. I test it by homing the printer then entering G1 Z0 and most of the time the Z gap is tight against the glass (to tight to print first layer). I repeat the procedure with G92 Z0 after adjusting the Z gap then runG30 S-1 and enter value in M558. Is there anything I can do to improve this.0_1547918741025_Z probe.jpg
                                            I am running 2.02
                                            M574 X1 S0 ; Define active low and unused microswitches
                                            M574 Y2 S0
                                            ;M574 Z1 S1
                                            M564 H0
                                            M558 P1 X0 Y0 Z1.297 H0 F500 T3000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
                                            G31 P500 X0 Y0 Z 1.1 ; Set Z probe trigger value, offset and trigger height
