    Smart effector not triggering on G30
    1.4k
    • Stoopundefined
      Stoop
      ; homedelta.g
      ; called to home all towers on a delta printer
      ; generated by RepRapFirmware Configuration Tool on Sun Feb 11 2018 10:18:09 GMT-0800 (Pacific Standard Time)
      G91 ; use relative positioning
      G1 S1 X650 Y650 Z650 F8000 ; move all carriages up 650mm, stopping at the endstops
      G1 S2 X-4 Y-4 Z-4 F1800 S2 ; move all carriages down 4mm
      G1 S1 X8 Y8 Z8 F360 ; move carriages slowly up 8mm, stopping at the endstops
      G1 Z-5 F6000 ; down a few mm so that we can centre the head
      G90 ; back to absolute positioning
      G1 X0 Y0 F6000 ; centre the head and set a reasonable feed rate
      ;config.g
      ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P2 ; Set firmware compatibility to look like Marlin
      ;M665 L480.687 R262.460 H385.081 B150.0 X-0.297 Y-0.297 Z0.000 ;M665 L494.726 R266.961 H386.657 B150.0 X-0.265 Y-0.243 Z0.000 ; Set delta radius, diagonal rod
      M665 L454.184 R254.97 H380 B150.0 X-1.06 Y-1.74 Z0.000
      M666 X-2.09 Y-0.62 Z0 A0.00 B0.00 ;Put your endstop adjustments here, or let auto calibration find them
      length, printable radius and homed height
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to switch and the dive height + speeds
      G31 p100 X0 Y0 Z-0.1 ; Set zprobe trigger height x36 y-17 Set Z probe trigger value, offset and trigger height
      M557 R150 S20 ; Define mesh grid
      M550 PBigDelta ; Set machine name
      M552 S1 ; Enable network
      M587 S"" ; Configure access point. You can delete this line once connected
      M587 S""
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S1 ; enable Telnet
      ;M569 P1 S1 ; Drive 1 burned out
      M569 P3 S0 ; Drive 3 goes forwards
      M569 P5 S1 ; Drive 5 goes forwards
      M584 X0 Y4 Z2 E3 ; Apply custom drive mapping
      M350 E16:16 I0 ; Configure microstepping without interpolation for extruder
      M350 X32 y32 Z32 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z160 E150 ; Set steps per mm
      M566 X72000 Y72000 Z72000 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 H0 S80 ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      ;M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
      ;M143 H2 S280 ; Set temperature limit for heater 2 to 280C
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X-7.5 Y8 Z0 ; Set tool 0 axis offsets
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X40 Y5 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M106 P0 S.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S0 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      ;Heaters
      M307 H0 G118.4 C996.4 D1.0 S1.0 V12.6 B1
      M307 H1 A249.9 C101.0 D2.8 S1.00 V12.6 B0
      M307 H2 A567.4 C282.6 D5.1 S1.00 V12.6 B0
      M501
      T0
        dc42 administrators @Stoop
        @stoop said in Smart effector not triggering on G30:
        I've just installed the smart effector, and hooked it up to my Duet Wifi.
        I tap the hot-end, and the green light blinks, but when I run the G30, it doesn't stop heading down.
        Where is my problem likely to be?
        Possibly a short between the Z probe IN and GND pins on the Duet, or between OUT and GND on the effector, or in the cable. If you unplug the 8-way cable from the effector, the Z probe reading should jump to 1000. Does it?
        • Stoopundefined
          Stoop
          no shorts in cable, checked all the runs. I'll check for shorts while everything is plugged in, z-probe is currently returning 0.
          • Stoopundefined
            Stoop
            unplugging 8 way cable returns 1000
            • aidarundefined
              aidar
              P parameter in G31 is p in your config. Shouldnt it be P ? I mean capital letter or how you call it in english...
                Check the underside of the Smart Effector for a solder bridge between the pins of the 8-way connector.
                • Stoopundefined
                  Stoop
                  4k ohms between zprobe in and gnd on duet (tested from 8-way plug)
                  Aidar, changed, I'll test. I think duet handles this though.
                  • Stoopundefined
                    Stoop
                    no solder bridge. nothing reading as a short anyway.
                    • Stoopundefined
                      Stoop
                      Aidar - No change after capitalization.
                      • Stoopundefined
                        Stoop
                        DC42 - Is there any way to log the zprobe hit? like can I just put a LED between 2 pins and see if it blinks?
                        I also can hook up my oscilliscope if I know what I'm looking for.
                          @stoop, yes you can connect an LED between output and ground.
                          The schematic is is at https://github.com/T3P3/SmartEffector/blob/master/SmartEffector/SmartEffector_v1.3/SmartEffector_Schematic_v1.3.pdf. You will see that same pin of the attiny MCU drives the LED through a 150 ohm resistor, and the output pin through a 1K resistor. If the 1K resistor was open circuit then you would get a Z probe reading of 1000 all the time because of the pullup resistor in the Duet.
                          • Stoopundefined
                            Stoop
                            @dc42 I get a v+(3,3?) blip on z_probe_in on the duet wifi board when I tap the hot end.
                            So, either Duet wifi board, or config is wrong.
                            How can I see what the firmware is seeing?
                            Can I run the Z_Probe_in to somewhere else?
                            • Stoopundefined
                              Stoop
                              Maybe I'll start the config.g from scratch.. But you see what I have there, nothing misconfigured?
                                Please send M558 without parameters, and check that the values it reports match those values in config.g. Also send G31 T5 to check that the G31 parameters are correct.
                                • Stoopundefined
                                  Stoop
                                  M558
                                  Z Probe type 5, invert no, dive height 5.0mm, probe speed 1200mm/min, travel speed 6000mm/min, recovery time 0.40 sec, heaters normal, max taps 1, max diff 0.03
                                  G31 T5
                                  Threshold 100, trigger height -0.10, offsets X0.0 Y0.0
                                  • Stoopundefined
                                    Stoop
                                    Ok, Been farting around.
                                    When I tap the hot-end, the Zprobe on the web interface DOES go to 1000.
                                    But it doesn't stop diving on the G30.
                                    What the heck?
                                    I just re-updated the firmware to the latest 2.02
                                    Same thing.
                                      Most strange:
                                      • You have verified that you are getting a 3.3v pulse on that signal
                                      • If you disconnect the Smart Effector from the Z probe input, the Z probe reading changes from 0 to 1000, so the Z probe input is working
                                      You could try using P8 instead of P5 in the M558 command to get a faster response; but the pulse should be plenty long enough for P5 to work too.
                                      • Stoopundefined
                                        Stoop
                                        Yes, I can SEE the pulse on the web interface, I can't imagine its not long enough, but I'll try that now.
                                        I USED to have a mechanical z-probe, is there some other setting I might have changed?
                                          Please confirm that this is the test you are doing:
                                          • Position the effector well above the bed.
                                          • Send G30. [Printer must previously have been homed.]
                                          • Effector moves towards the bed
                                          • Tap the nozzle upwards
                                          • The green LED on the effector should flash, and the downward movement should stop at the same time.
                                          • Stoopundefined
                                            Stoop
                                            Well, I deleted my config.g override, and changed to p8. It stopped travel.
                                            Changed back to p5, seems to be working now.
                                            Odd, nothing in the config override should have been doing anything, but it seems to be working now.
                                            Thanks for all your help @dc42
