    Period in SSID
    ssid period . duet 2 wifi
    2.0k
      dc42 administrators @jamesadoty
      @jamesadoty said in Period in SSID:
      I removed the MicroSD card and took a look at config.h and it shows my SSID and password. I believe the format is:
      M587 S"belkin.c6f" P"<password>" <- the password is set to my SSID password.
      That M587 command shouldn't be in config,g, it should either be in a macro file that you execute after the Duet has started up, or you should send it to the USB port vis a terminal emulator. See https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s5.
      jamesadotyundefined 1 Reply Last reply Reply Quote 0
      • jamesadotyundefined
        jamesadoty @dc42
        I'd better double check that when I get home after work, I could swear it was there but I've been known to be wrong.
        I do recall reading something about macros, I'll take a look tonight.
        In fact I wonder if a macro for that is already there and is set to the SSID I see when I type M587 from the LCD screen.
        I don't really want to unplug all those cables to take my Duet board to my computer if I don't have to.
        I haven't had a 3D printer connected directly to my computer in years. Very liberating. 🙂
          If your password isn't too long, you can send the M587 command from PanelDue. Otherwise, put the M587 command in a macro file on the SD card and execute that.
            jamesadoty @dc42
            My SSID password isn't terribly long but is in all lowercase, I can't figure out how to get quote marks or type lowercase characters from the LCD panel.
            I'll try the macro idea though.
            I suppose if worse comes to worse I could borrow a laptop from work.
            Hey, as a thought. I do have a Chromebook. I wonder if there's a terminal program for it that works through USB??? Hmm.
              If you have recent firmware on the PanelDue then there is a Shift key on the keyboard to switch to lowercase and punctuation characters.
              • SupraGuyundefined
                SupraGuy
                I'm pretty sure that the RRF configuration tool will happily put your SSID and password into the config.g file. I did mine, though I removed it after the printer connected to the network.
                Putting it into a macro file to generate is also not a bad idea.
                I might do such a macro as follows:
                ; wifimacro.g
                ; tell the Duet to connect to the wifi
                M552 S0                     ; Turn off the wifi module
                M588 "*"                    ; forget all current SSID networks
                M587 S"WI.FI.SupraGuy" P"supraguyssupersecurepassword"
                M552 S1                     ; turn the wifi module back on
                Lead screw driven printer, powered by Duet 2 Wifi
                MPCNC powered by Duet 2 Wifi
                CoreXY printer driven by Duet 3 6HC
                LowRider CNC powered by Duet 2 Wifi
                  jamesadoty @dc42
                  My next step will be to update the firmware then. I think it has version 1.17?? Not sure but I did see it wasn't current.
                    jamesadoty @SupraGuy
                    @supraguy
                    Great script. I'll create one myself and give it a try.
                      M587 is supported in firmware 1.19 and later.
                        jamesadoty
                        No progress yet.
                        Here's my script file.
                        ; SetNetwork macro to set up wifi
                        ; Tell Duet to connect to the wifi
                        M552 S0 ; turn off wifi
                        M588 S"*" ; forget all stored networks, remove if this works
                        ; G4 P1000 I commented this out
                        M587 S"belkin.c6f" P"<password_secret> :)"
                        ;M587 I commented this out
                        M552 S1 ; turn on wifi
                        ; M552 I commented this out
                        I found out that the file originally contained a dummy network set up and that's what's in the system, M588 S"*" doesn't seem to get rid of it though.
                        Is there another command used to erase a setting from permanent memory?
                          jamesadoty
                          Time to sing it:
                          "Happy Happy Joy Joy Joy!!!"
                          The learning curve is killing me. But some progress made!
                          I thought macros were automatically run. Nope. Did some research. Tried:
                          P/macros/setnetwork.
                          Nope, no go.
                          Did even more research
                          M98 p/macros/setnetwork
                          M587 showed belkin.c6f but no IP address or netmask or anything, all zeros.
                          Rebooted, ran M587. Connected with an IP address!!!!
                          Thank you all of you who helped me figure this out.
