    DuetWiFiServer 1.22 released
    Firmware installation
    3.3k
    • lolorcundefined
      lolorc @Eddiie
      @eddiie just by upgrading dws, errors have changed from tcp dups to tcp resets. this is an issue with the firmware not with my network. I have devices connected to it, it works flawlessly with them...
      from what I read here https://github.com/dc42/DuetWiFiSocketServer/commit/0d7fbff977eec9dc132825cdc75f26020e0136de it's still WIP.
      I'd rather limit my duet wifi server to send 1 file at a time rather than having those bl**dy issues.
      I'm using some sort of proxy that I have written to circumvent those issues. I have a rpi attached to the usb serial port, a simple python web server serves all the static files (that i have locally on the rpi), some rr_cmd are translated to gcodes sent through serial port, some are just proxied back to the duet wifi server.
      At the moment that's my way to use my duet.
      0 dc42 committed to dc42/DuetWiFiSocketServer
      Version 1.22beta1
      Changes for version 1.22.1 beta release. Projects LwipESP8266 and CoreESP8266 are also changed.
        @lolorc, please can you follow up these suggestions that have already been made:
        • Connect a PC via USB, enable WiFi debug and see if you get any debug messages when the errors occur
        • Take the Duet to a friend's house and see whether it will work properly on another network. If it won't then perhaps the WiFi module is faulty.
        • lolorcundefined
          lolorc @lolorc
          @lolorc said in DuetWiFiServer 1.22 released:
          my way to upload gcode files, my way to use my printer is to upload gcode files through usb with M559. Most of the time I have a program reading the usb serial port. There's no specific wifi debug messages.
          M111 P14 S1 has been in my config.g for months...
            dc42 administrators @lolorc
            Yes, but do you have a PC connected via USB to receive the debug data? If you do then you should see some messages when the WiFi module starts up. If it detects a problem, you may see further messages.
            You should most definitely not use M111 P14 S1 if you do not have a PC connected running a termninal emulator or Pronterface etc. to receive the USB data.
            • lolorcundefined
              lolorc
              I have a raspberry connected to the usb, reading the usb port all the time.
              I can see the ssid list, and the connection getting successful, after that, there isn't any specific message, no error, no reconnection.
              Same goes if I enable storage/network/webserver debug, I can see the connection, data being received from network, data being read/written from/to sdcard, but no specific error when the TCP connection is reset.
              M111 P14 S1 is in my config.g because my rpi is always connected and reading the usb serial port as this is my only way to upload files with M559.
              I also tried to unplug rpi + disable any log, I still have the tcp issues.
              I'll check my sdcard cluster size this evening, and I'll try to reproduce with another AP, No need to move my duet to a friend, I'll use an android phone as an AP and will connect my pc to it. I'll do that with the sdcard I'm using atm, I'll do it again with the brand new sdcard I used last week to diagnose sdcard issues.
              Will report back as soon as done.
              This duet board is a replacement board I bought from T3P3 2 years ago after I shorted 24V and 3.3V...
                This is what I get when I have a terminal session connected to a Duet WiFi and I use M552 to disconnect and reconnect while WiFi debugging is enabled. You should see something very similar, with ***** replaced by the SSID of your network.
                m115
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02+1 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2019-01-15b1
                ok
                m111 s1 p14
                Debugging enabled for modules: WiFi(14)
                Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
                ok
                m552 s0
                ok
                WiFi: state: 5 -> 0 (0)
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: del if0
                WiFi: usl
                WiFi: mode : null
                WiFi module is idle
                m552 s1
                ok
                WiFi: mode : sta(60:01:94:09:ae:34)
                WiFi: ip:0.0.0.0,mask:255.255.255.0,gw:192.168.1.254
                WiFi: add if0
                WiFi: scandone
                WiFi: ../src/SocketServer.cpp(353): found network ASUS_Guest1
                WiFi: ../src/SocketServer.cpp(353): found network *****
                WiFi: sleep enable,type: 2
                WiFi: scandone
                WiFi: state: 0 -> 2 (b0)
                WiFi: state: 2 -> 3 (0)
                WiFi: state: 3 -> 5 (10)
                WiFi: add 0
                WiFi: aid 2
                WiFi: cnt
                WiFi:
                WiFi: connected with *****, channel 12
                WiFi: dhcp client start...
                WiFi: ip:192.168.1.125,mask:255.255.255.0,gw:192.168.1.254
                WiFi module is connected to access point *****, IP address 192.168.1.125
                WiFi: pm open,type:2 0
                lolorcundefined 1 Reply Last reply Reply Quote 0
                • lolorcundefined
                  lolorc @dc42
                  @dc42 🙂
                  yes that's obviously what I've also been getting.
                  and this is what I get after I just powered on the printer and tried to upload a 25MB gcode file, which was obviously unsuccessful.
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.0 or 1.01
                  Used output buffers: 5 of 20 (15 max)
                  Static ram: 25524
                  Dynamic ram: 98612 of which 0 recycled
                  Exception stack ram used: 256
                  Never used ram: 6680
                  Tasks: NETWORK(ready,648) HEAT(blocked,1232) MAIN(running,3840) IDLE(ready,200)
                  Owned mutexes:
                  Last reset 00:03:48 ago, cause: power up
                  Last software reset at 2019-01-14 11:06, reason: User, spinning module GCodes, available RAM 6592 bytes (slot 3)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                  Error status: 0
                  Free file entries: 10
                  SD card longest block write time: 7.0ms, max retries 0
                  MCU temperature: min 16.0, current 16.7, max 16.9
                  Supply voltage: min 0.5, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                  Driver 0: ok, SG min/max not available
                  Driver 1: ok, SG min/max not available
                  Driver 2: ok, SG min/max not available
                  Driver 3: ok, SG min/max not available
                  Driver 4: ok, SG min/max not available
                  Date/time: 2019-01-15 17:35:50
                  Cache data hit count 777694634
                  Slowest loop: 57.19ms; fastest: 0.06ms
                  I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                  Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                  Bed compensation in use: mesh
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is ready with "M122" in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 207.27ms; fastest: 0.08ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is running
                    Failed messages: pending 0, notready 0, noresp 1
                    WiFi firmware version 1.22
                    WiFi MAC address
                    WiFi Vcc 3.27, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 27448
                    WiFi IP address
                    WiFi signal strength -55dBm, reconnections 0, sleep mode modem
                    ok
                    WiFi: MEM PBUF_POOL avail:␡Conns: 0:free, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
                    WiFi: IP xmit: 730 recv: 650 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 0
                    WiFi: TCP xmit: 521 recv: 623 fw: 0 drop: 0 chkerr: 0 lenerr: 0 memerr: 0 rterr: 0 proterr: 0 opterr: 0 err: 0 cachehit: 609
                    WiFi: MEM UDP_PCB avail: 4 used: 4 max: 4 err: 0
                    WiFi: MEM TCP_PCB avail: 8 used: 6 max: 8 err: 0
                    WiFi: MEM TCP_PCB_LISTEN avail: 4 used: 2 max: 2 err: 0
                    WiFi: MEM TCP_SEG avail: 16 used: 0 max: 6 err: 0
                    WiFi: MEM ARP_QUEUE avail: 10 u␡MEM PBUF_REF/ROM avail: 10 used: 0 max: 0 err: 0
                    I'm sorry, that's not obvious at all, because you didn't say you were getting any debug information at all. Which led me to think that you were not monitoring the debug output.
                    Let's see what happens when you try using your phone as an AP.
                    • lolorcundefined
                      lolorc
                      Good news, it's not my esp as it's working flawlessly with my android ap.
                      So I guess I need to investigate what's going on with my cisco APs (2 of them, Multiples SSID, etc...)
                      Sorry for the noise,
                      Thanks for the patience and answers.
                      I'll report back as soon as I find something relevant.
                      • grizewaldundefined
                        grizewald
                        Would this buffer problem explain why I have been experiencing problems uploading files to my first ever Duet2 WiFi?
                        I've had various manifestations of the problem: once a failed save of an edit to config.g in the browser, several times starting an upload of a g-code file and then seeing the transfer stall after a couple of MB and then error out.
                        The first time I had trouble uploading a g-code file, rebooting solved the problem. The second time, even a reboot and immediate re-upload resulted in the transfer stalling and terminating with an error. When that happened, I shut down, powered off and put the SD card in my Linux laptop. I checked the file system on the card (and cleared the dirty bit) and read the entire card with dd without issue.
                        My hardware is a genuine Duet2 WiFi from duet3d.com in the UK. When I got to testing my new printer just before Christmas, I updated both the Duet and the PanelDue 7i that I have to the latest releases of their firmware when 2.02 was released.
                        Everything works fine except for these spurious file transfer errors.
                          dc42 administrators @grizewald
                          @grizewald said in DuetWiFiServer 1.22 released:
                          It's hard to know for sure what conditions could cause the WiFi module firmware to run out of buffers, other than the condition that DWC 2.0RC2 was good at triggering. I do know that some users experienced more disconnects when we switched to the new WiFi firmware architecture, which is probably when the buffer exhaustion problem started. However, we also adopted the new SDK from Expressiv at that time, and that included some major changes including adjustments to the output power.
                          So I recommend that you upgrade to the 2.02a firmware bundle, which includes DuetWiFiServer 1.22. In particular, if you are already running DuetWiFiServer 1.21, then upgrading it to 1.22 is low-risk.
                          grizewaldundefined 1 Reply Last reply Reply Quote 0
                          • lolorcundefined
                            lolorc
                            https://forum.duet3d.com/topic/879/wifi-rant-alert/13
                            I have two cisco APs, I've disabled the 2.4GHz network interface on my a1140, letting only the 1600 two floors under working, it also works better ! 🙂
                            I guess I'll find a way to get another a1600 😉
                              grizewald @dc42
                              @dc42 Thanks. I'll be doing some more tuning on the printer this weekend, so I'll update first and keep an eye on it.
                              If I do still get the problem after updating, what kind of information should I collect to help diagnose the cause?
