Chamber temp and fan
I would like to install a thermistor to monitor Chamber/Enclosure temperture and if its too high then Turn on an exhaust fan to remove some heat
is this possible?A
is this possible?A
Yes that's possible. I'm going to do the same thing but measure the stepper driver temperature to turn on/off a fan in the Duet enclosure.
Connect the thermistor to spare channel (say E1) then use M106 to set the fan to monitor that channel and set the temperature threshold at which it will come on.
