    M42 For LED Control Not Working
    • Eth7anundefined
      Eth7an
      I have been reading up on the GCode necessary to convert one of my Pwm fan headers into a dimmable LED control. To do this I have disabled the fan using M106 P2 I-1 and then tried to use the M42 Command to activate that pin. I still have the header connected to a fan while I try to get it working, but the command does nothing to the fan and returns an error:
      If anybody knows what Ive done wrong, that would be a ton of help!
      Thanks for the help, Ethan
      Eth7anundefined 1 Reply Last reply Reply Quote 0
      • Eth7anundefined
        Eth7an @Eth7an
        @eth7an If it helps, I'm using a DUET 2 Ethernet on the latest firmware version. I have the fan connected to the Fan header 2 as well, even though I have tried all of them.
        • Eth7anundefined
          Eth7an
          I have also tried these, however none of them have any effect on my connected fan 😞0_1548599069396_57372944-3725-4c21-a658-c7ef65db6a2e-image.png
            Fan 2 output is logical pin 22, not 2. Logical pin 2 is heater 2 output.
            • Eth7anundefined
              Eth7an
              Thank you, that worked!
