    Extruder not working on new install (upgrade)
    • AKLivingundefined
      AKLiving
      My extruder stepper motor just vibrates with minimal movement of the filament. Turning the mA up from 500 to 1000 makes it vibrate with a very fast, loud clicking but the filament moves. Previously working fine on my OEM Tronxy controller at 500mA and running smooth. I tried swapping motors and got the same. Tried the motor on the X axis and it worked fine. I tried swapping wiring with the same result. So, I'm sure its not the motor or wiring. config appears to be similar to many other working setups. This is a new installation replacing a working OEM setup. Did I get a bad stepper driver? I'm no expert at checking that but no obvious physical signs of a problem. I'm struggling with setting it up as an access point as well but will start a separate thread for that.
      Machine: Tronxy X5SA
      Stepper motor for extruder: LDO Overthemoon, 1.8deg, 1A. Tried the Tronxy OEM motors too.
      Controller: Duet WiFi
      Versions: firmware 2.02a, web control 1.22.6, server 1.22
      I can't get config.g to upload due to poor internet connection so here is a text copy of my settings if it could be helpful.
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Jan 23 2019 15:02:09 GMT-0900 (Alaska Standard Time)
      M667 S1 ; Select CoreXY mode
      M550 P"TronxyX5SA" ; Set machine name
      M552 S2 ; Enable as an access point
      M589 S"TronxyC5SA" P"--------" I192.186.2.100 ; Configure access point parameters. Set SSID, WiFi password, & IP address to use.
      M569 P0 S0 ; Drive 0 goes backwards
      M569 P1 S0 ; Drive 1 goes backwards
      M569 P3 S0 ; Drive 3 goes backwards
      M92 X80.00 Y80.00 Z400.00 E418.5 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z6000.00 E600.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1000.00 E100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X40 Y40 Z0 S1 ; Set axis minima
      M208 X330 Y330 Z400 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M574 Z1 Z2 S2 ; Set endstops controlled by probe
      M558 P5 I1 H5 F120 T6000 A10 R0.5 B0 ; Set Z probe type to modulated and the dive height + speeds
      G31 P500 X-30 Y-40 Z5.35 ; Set Z probe trigger value, offset and trigger height
      M556 S50 X0 Y0 Z0 ; Set orthogonal axis compensation parameters
      M557 X55:330 Y65:330 S15 ; Define mesh grid
      M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S300 ; Set temperature limit for heater 1 to 300C
      M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      M501 ; Load saved parameters from non-volatile memory
      AKLivingundefined 1 Reply Last reply Reply Quote 0
      • AKLivingundefined
        AKLiving @AKLiving
        I forgot to also say that I checked continuity of the motors and wires where were fine. But them working on other axis should have proven that as well. It is in a printed PLA case (Ocie's Box) with nothing anywhere near it that could be grounding it out. Unless there's something I'm missing in the firmware then I'm not sure what else to check. I don't know how to check the stepper driver itself.
        • Vetiundefined
          Veti
          is 100ma for the extruder correct? that seems a bit low.
          maybe you mistyped and missed a 0
            It looks like your E1 motor output is free. So you can try connecting it to the E1 output instead of E0, then change D0 in your M563 command in config.g to D1. Leave the heater wiring alone. If that fixes it then the E0 stepper driver is probably faulty.
            • Vetiundefined
              Veti
              E1 in his current configuration will also only receive 100mA. So it will result in the same problem.
              • AKLivingundefined
                AKLiving
                I caught the E0 set at 100mA. It was a typo when I was trying higher settings and corrected it during my testing. My results described above were using 500mA (mA used with previous setepper driver and verified with a voltmeter) and 1,000mA.
                I'll try using E1 output when I get home tonight.
                • AKLivingundefined
                  AKLiving
                  E1 worked the same. I decided to break down the extruder and make sure nothing was mechanically causing this because it sure had a mechanical sound. I didn't find anything wrong but when reassembled the problem resolved. Who knows what could have caused the problem at the same time I upgraded to the Duet WiFi but I sure am glad it wasn't the Duet.
                  Thank you for the help. It's hard to believe the level of support for this product. I have already spread the word to almost everyone I know. I learned a little more through the process and for that I am very thankful. Now if I can solve the access point connection problem I'll be set.... until my next upgrade.
