    Haq XY
    Firmware developers
    15.3k
    • Haggan90undefined
      Haggan90 @dc42
      @dc42 I just tried what you sugested.
      This is the result:
      G1 S2 X20 - Moves only the X axis
      G1 S2 X-20 - Moves only the X axis
      G1 S2 Y20 - Moves every axis (XYU) (only the Y motor turns)
      G1 S2 Y-20 - Moves every axis (XYU) (only the Y motor turns)
      G1 S2 U20 - Moves only the U axis
      G1 S2 U-20 - Moves only the U axis
      If I understood you correctly G1 S2 Y20 should only move the Y axis, so the U and X should cooperate as stated in the M669 command correct?
      Just to be clear, if I send G1 S1 Y20 the Y axis works as i should.
        dc42 administrators @Haggan90
        @haggan90 said in Haq XY:
        This is the result:
        That's all exactly as it should be. Only the motor you commanded moves, the other motors stay still. The Y motor moves all 3 axes - that's the nature of the kinematics you are using.
        If you remove the S1 from the commands, then only the specified axis should move. The commands to move Y will also move the X and U motors so as to keep the X and U positions constant. Commands to move X or U will move just the X or U motor as before. You will have to send M564 H0 first if the axes haven't been homed.
        I think some of the issues you have been getting may be because not all motors have been energised at full power while executing the commands. I'll change the code to do that automatically. Meanwhile, please test the printer again (including G29), but this time run these commands first to ensure that all motors are energised:
        M906 I100 ; prevent idle current reduction
        G91 ; relative mode
        G1 S2 X0.1 Y0.1 U0.1 ; energise all 3 motors
        G90 ; absolute mode
        You can put those in a macro to save typing it in every time.
        Haggan90undefined 1 Reply Last reply Reply Quote 0
        • Haggan90undefined
          Haggan90 @dc42
          @dc42 Same things happends.
          This is my config.g file now, I've changed so that Y home's to max and also U. X homes to min.
          Please let me know if you find anything faulty, I'm beginning to think there is something wrong here if you manage to get it to work.
          M584 X0 U6 Y1 Z2:5 E3:4 ; set 3 Z drivers and add one U driver
          M569 P5 S0 ; Drive 5 goes backwards
          M569 P6 S1 ; Drive 6 goes forwards
          M669 K0 Y1👎0:-1 ; set Y to react with X and U
          M350 U16 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
          M92 U80.00 X80.00 Y240.00 Z1066.67 E420.00:420.00 ; Set steps per mm
          M566 U900.00 X900.00 Y900.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 U10000.00 X10000.00 Y10000.00 Z500.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
          M201 U800.00 X800.00 Y800.00 Z20.00 E250.00:250.00 ; Set accelerations (mm/s^2)
          M906 U1000.00 X1000.00 Y1000.00 Z1000.00 E800.00:800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 U0 X0 Y0 Z0 S1 ; Set axis minima
          M208 U540 X540 Y550 Z750 S0 ; Set axis maxima
          M574 U2 S0 ; Set active low endstops
          M574 X1 Y2 S1 ; Set active high endstops
          M574 Z1 S2 ; Define Z to use Probe. Home to Min.
          M558 P9 H5 F500 T4000 ; Set Z probe type/mode 9.
          G31 P25 X0 Y-57.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
          M557 X40:490 Y70:480 S50 ; define mesh grid
          ; BLTouch - Heaters
          M307 H3 A-1 C-1 D-1 ; Disable the 2nd Heater to free up PWM channel 1 on the Duex board
          M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
          M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1 F0 ; tool 0 uses extruder 0 and heater 1
          G10 P0 X0 Y0 Z0 R0 S0 ; set tool 0 offsets and temperatures
          M563 P1 D1 H2 X3 F2 ; tool 1 uses extruder 1 and heater 2 and maps X to U, use fan 2 as the print cooling fan
          G10 P1 X0 Y0 Z0 R0 S0 ; set tool 0 offsets and temperatures
          This is my homeall.g atm.
          G91 ; relative positioning
          G1 S1 Y550 U540 X-540 F2500 ; move quickly to Y axis endstops and stop there (first pass)
          G1 S1 Y550 F2500 ; Home Y seperate
          G1 S1 X-540 F2500 ; Home X seperate
          G1 S1 U540 F2500 ; Home U seperate
          G1 Y-5 X5 U-5 F2000 ; Go back 5mm on all axis
          G1 S1 Y550 F600 ; slowly home Y
          G1 S1 X-100 F600 ; Slowly home X
          G1 S1 U100 F600 ; Slowly home U
          G90 ; absolute positioning
          G1 S1 X300 Y310 F2500 ; go to first bed probe point and home Z
          G1 S2 Z5 F100 ; lift Z relative to current position
          IF either U or X are at their endstop when I do homeall, they allways crashes into them again.
          also, G1 S1 X300 Y310 F2500 doesen't seem to work either 😞
            Do you mean that it never works, or that it doesn't work if either U or X are at their endstop when you do homeall? In what way does it not work?
            • Haggan90undefined
              Haggan90 @dc42
              @dc42 said in Haq XY:
              If either U or X are at their endstop.
              Could it be that when either U or X are at their endstop it interfears with the M669 matrix?
                And it what way does G1 S1 X300 Y310 F2500 not work?
                Please provide your current homing files.
                  PS:
                  1. Please clarify what you have in your M584 command in config.g, because it's not been rendered correctly in the config.g you listed a few posts ago.
                  2. When you send
                  G91 G1 S2 Y20
                  in what directions do the Y, X and U axes move?
                  • Haggan90undefined
                    Haggan90 @dc42
                    PS:
                    2. When you send
                    G91 G1 S2 Y20
                    1. M584 X0 U6 Y1 Z2:5 E3:4
                    2. Y moves forward, X moves left (-) and U moves right(+)
                    • wilrikerundefined
                      wilriker
                      Small aside: putting the contents of e.g. config.g in paired blocks of three backticks (```) will activate code-styling in the forum. This should prevent automatic emoji replacements.
                      Manuel
                      My Tool Collection
                      Haggan90undefined 1 Reply Last reply Reply Quote 1
                      • Haggan90undefined
                        Haggan90 @wilriker
                        @wilriker Thank you very much!
                        M569 P0 S1                                      ; Drive 0 goes forwards
                        M569 P1 S1                                      ; Drive 1 goes forwards
                        M569 P3 S1                                      ; Drive 3 goes forwards
                        M669 K0 Y1:-1:0:-1				; set Y to react with X and U
                        ; BLTouch - Heaters
                        M143 H0 S120                                    ; Set temperature limit for heater 0 to 120C
                        M143 H1 S280                                    ; Set temperature limit for heater 1 to 280C
                          Please elaborate on "Y moves forwards". Do you mean that the carriage moves towards you (in the -Y direction), or away from you (in the +Y direction)?
                          I think I've just found a bug that may explain some of the homing issues. Also I think your matrix is wrong.
                          • Haggan90undefined
                            Haggan90 @dc42
                            @dc42 Huh, it actually move towards me, in the -Y direction!
                            I tried to push the <Y-10 afterwards and both U and X moved superfast (like 400mm/s) at diffrent direction, around 50mm. X at - and U at +.
                            Why do you think the matrix is wrong?
                            It works just as it should work when using the toggle buttons (or what they are called at the "Machine Control")
                              @haggan90, I think the matrix may be unconventional, but valid. To make it conventional, you could change S1 to S0 in your M569 P1 line (to reverse Y motor direction), and change the M669 command to:
                              M669 K0 Y-1:1:0:1
                              Your X and U axes appear to be affected by the Y motor in opposite directions, so I guess you have one of those carriages attached to the front of the its belt and the other one to the back of its belt, or something like that. But it doesn't matter, as long as all the axes move correctly in response to the jog commands.
                              I've implemented a fix for the bug that I think I found, however I also want to fix it so that if you try to move X or U, it also energises the Y motor to lock it; and if you do a diagonal homing move then it energises the X and U motors to lock them. So I'll implement that tomorrow, test G29, then make a new binary available.
                              Meanwhile, I think most things should work if you home the axes individually, doing Y before X and U.
                              • Haggan90undefined
                                Haggan90 @dc42
                                @dc42 I just reversed the Y motor and when I do G1 X10 F1000 S2 the Y axis moves in the right direction (+10).
                                But I've noticed a new thing when homing.
                                This is my homeall.g now:
                                G1 X300 Y310 F2500        	; go to first bed probe point and home Z
                                But when it comes to G1 X300 Y310 F2500 the X axis just smashes into it's endstop.
                                It seems like both U and X looses their position somehow, or that X and U switches...so X becomes U and U becomes X.
                                If I manually home Y first and then try to home X the U axis moves.
                                If I manually home U and X first, their postion is X0 U550.
                                If I then home Y manually X position is X1100.3 and U is U-560.
                                Does this make any sense at all?
                                MaxGyverundefined 1 Reply Last reply Reply Quote 0
                                  I've found a bug in the optimisation of the kinematics calculations. I have just fixed this and my initial tests seem OK. I'd like to run more tests, but it's late now so I will continue this tomorrow. If you want to try the latest binary, it's at https://www.dropbox.com/s/fyvibzm0zl92hiy/Duet2CombinedFirmware.bin?dl=0.
                                  • Haggan90undefined
                                    Haggan90 @dc42
                                    I can't wait to try this when I get home from work!
                                    Did you test the G29 in your test rig?
                                      Not yet, but I hope to get the tests completed this afternoon.
                                      The previous firmware got the positions wrong after homing. It was confusing to debug, because your original M669 command results in a matrix whose inverse was identical to itself! So for some time I thought that the matrix inversion code wasn't working.
                                        I just did some more tests including G29. It looks to me that it is working properly.
                                        • Haggan90undefined
                                          Haggan90 @dc42
                                          @dc42 Great job! It seems to be working now, only updated the firmware and homing + G29 worked straight away! 😄
                                            @haggan90, thanks for confirming. I'm sorry it took so long to get it right. They say "premature optimisation is the root of all evil!" and I think there is some truth in that.
