    Haq XY
    Firmware developers
    15.3k
    • Haggan90undefined
      Haggan90 @wilriker
      @wilriker Thank you very much!
      M584 X0 U6 Y1 Z2:5 E3:4				; set 3 Z drivers and add one U driver
      M569 P0 S1                                      ; Drive 0 goes forwards
      M569 P1 S1                                      ; Drive 1 goes forwards
      M569 P2 S0                                      ; Drive 2 goes backwards
      M569 P3 S1                                      ; Drive 3 goes forwards
      M569 P4 S1                                      ; Drive 4 goes forwards
      M569 P5 S0                                      ; Drive 5 goes backwards
      M569 P6 S1                                      ; Drive 6 goes forwards
      M669 K0 Y1:-1:0:-1				; set Y to react with X and U
      M350 U16 X16 Y16 Z16 E16:16 I1                      		; Configure microstepping with interpolation
      M92 U80.00 X80.00 Y240.00 Z1066.67 E420.00:420.00      		; Set steps per mm
      M566 U900.00 X900.00 Y900.00 Z12.00 E120.00:120.00      	; Set maximum instantaneous speed changes (mm/min)
      M203 U10000.00 X10000.00 Y10000.00 Z500.00 E1200.00:1200.00 	; Set maximum speeds (mm/min)
      M201 U800.00 X800.00 Y800.00 Z20.00 E250.00:250.00      	; Set accelerations (mm/s^2)
      M906 U1000.00 X1000.00 Y1000.00 Z1000.00 E800.00:800.00 I30 	; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                         		; Set idle timeout
      M208 U0 X0 Y0 Z0 S1                          ; Set axis minima
      M208 U540 X540 Y550 Z750 S0                  ; Set axis maxima
      M574 U2 S0					; Set active low endstops
      M574 X1 Y2 S1                               	; Set active high endstops
      M574 Z1 S2 					; Define Z to use Probe. Home to Min.
      M558 P9 H5 F500 T4000				; Set Z probe type/mode 9.
      G31 P25 X0 Y-57.3 Z0.0 				; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X40:490 Y70:480 S50			; define mesh grid
      ; BLTouch - Heaters
      M307 H3 A-1 C-1 D-1 				; Disable the 2nd Heater to free up PWM channel 1 on the Duex board
      M305 P0 T100000 B4138 R4700                     ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                    ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700                     ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280                                    ; Set temperature limit for heater 1 to 280C
      M106 P0 S0.3 I0 F500 H-1                        ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                ; tool 0 uses extruder 0 and heater 1
      G10 P0 X0 Y0 Z0 R0 S0                           ; set tool 0 offsets and temperatures
      M563 P1 D1 H2 X3 F2                             ; tool 1 uses extruder 1 and heater 2 and maps X to U, use fan 2 as the print cooling fan
      G10 P1 X0 Y0 Z0 R0 S0                           ; set tool 0 offsets and temperatures
        dc42 administrators @Haggan90
        @haggan90 said in Haq XY:
        Y moves forward, X moves left (-) and U moves right(+)
        Please elaborate on "Y moves forwards". Do you mean that the carriage moves towards you (in the -Y direction), or away from you (in the +Y direction)?
        I think I've just found a bug that may explain some of the homing issues. Also I think your matrix is wrong.
        Haggan90undefined 1 Reply Last reply Reply Quote 0
        • Haggan90undefined
          Haggan90 @dc42
          @dc42 Huh, it actually move towards me, in the -Y direction!
          I tried to push the <Y-10 afterwards and both U and X moved superfast (like 400mm/s) at diffrent direction, around 50mm. X at - and U at +.
          Why do you think the matrix is wrong?
          It works just as it should work when using the toggle buttons (or what they are called at the "Machine Control")
            @haggan90, I think the matrix may be unconventional, but valid. To make it conventional, you could change S1 to S0 in your M569 P1 line (to reverse Y motor direction), and change the M669 command to:
            M669 K0 Y-1:1:0:1
            Your X and U axes appear to be affected by the Y motor in opposite directions, so I guess you have one of those carriages attached to the front of the its belt and the other one to the back of its belt, or something like that. But it doesn't matter, as long as all the axes move correctly in response to the jog commands.
            I've implemented a fix for the bug that I think I found, however I also want to fix it so that if you try to move X or U, it also energises the Y motor to lock it; and if you do a diagonal homing move then it energises the X and U motors to lock them. So I'll implement that tomorrow, test G29, then make a new binary available.
            Meanwhile, I think most things should work if you home the axes individually, doing Y before X and U.
            • Haggan90undefined
              Haggan90 @dc42
              @dc42 I just reversed the Y motor and when I do G1 X10 F1000 S2 the Y axis moves in the right direction (+10).
              But I've noticed a new thing when homing.
              This is my homeall.g now:
              G91 				; relative positioning
              G1 Z5 F6000 S2 			; lift Z relative to current position
              G1 S1 Y550 U540 X-540 F2500 	; move quickly to Y axis endstops and stop there (first pass)
              G1 S1 Y550 F2500		; Home Y seperate
              G1 S1 X-540 F2500		; Home X seperate
              G1 S1 U540 F2500		; Home U seperate
              G1 Y-5 X5 U-5 F2000		; Go back 5mm on all axis
              G1 S1 Y550 F600			; slowly home Y
              G1 S1 X-100 F600		; Slowly home X
              G1 S1 U100 F600			; Slowly home U
              G90				; absolute positioning
              G1 X300 Y310 F2500        	; go to first bed probe point and home Z
              G30                     	; home Z by probing the bed
              G1 S2 Z5 F100          		; lift Z relative to current position
              But when it comes to G1 X300 Y310 F2500 the X axis just smashes into it's endstop.
              It seems like both U and X looses their position somehow, or that X and U switches...so X becomes U and U becomes X.
              If I manually home Y first and then try to home X the U axis moves.
              If I manually home U and X first, their postion is X0 U550.
              If I then home Y manually X position is X1100.3 and U is U-560.
              Does this make any sense at all?
              MaxGyverundefined 1 Reply Last reply Reply Quote 0
                I've found a bug in the optimisation of the kinematics calculations. I have just fixed this and my initial tests seem OK. I'd like to run more tests, but it's late now so I will continue this tomorrow. If you want to try the latest binary, it's at https://www.dropbox.com/s/fyvibzm0zl92hiy/Duet2CombinedFirmware.bin?dl=0.
                • Haggan90undefined
                  Haggan90 @dc42
                  I can't wait to try this when I get home from work!
                  Did you test the G29 in your test rig?
                    Not yet, but I hope to get the tests completed this afternoon.
                    The previous firmware got the positions wrong after homing. It was confusing to debug, because your original M669 command results in a matrix whose inverse was identical to itself! So for some time I thought that the matrix inversion code wasn't working.
                      I just did some more tests including G29. It looks to me that it is working properly.
                      • Haggan90undefined
                        Haggan90 @dc42
                        @dc42 Great job! It seems to be working now, only updated the firmware and homing + G29 worked straight away! 😄
                          @haggan90, thanks for confirming. I'm sorry it took so long to get it right. They say "premature optimisation is the root of all evil!" and I think there is some truth in that.
                          • Haggan90undefined
                            Haggan90 @dc42
                            @dc42 No problem at all, I'm just thankfull for all the help 😃
                            • Visionaryundefined
                              Visionary
                              Can Haq XY-kinematics be used with RRF3/6HC mainboard?
                              I'm planning on changing from 3-axis (x,y,z) Corexy to Haq XY (x,u,y,z) but I need to be sure there is a working firmware for it. I use 6HC mainboard in my machine so I assume I cannot use binary posted several post above.
                              Main printer: 3-5 Axis, 400x400x450 Duet 6HC || https://grabcad.com/eetu-4/models
                                Yes, RepRapFirmware supports any kinematics for which the movement of each axis is a linear combination of the movement of the motors.
                                • RootCNCundefined
                                  RootCNC
                                  Hi everyone,
                                  Are you able to share how you set this up? I'm currently knew to RepRap Firmware, as I'm a long time user of Marlin but due to the fact Marlin doesn't support this type of configuration. I'm currently looking to move over to RepRap Firmware and purchase a Duet 3 6HC board.
                                  I've actually already built this printer, photos attached. Its still got a little bit of work todo and due to the nature of Duet, Reprap and the open source community I intend to share this project among my other projects (Root CNC).
                                  I would much appreciate any help on configuring this type of kinematics as it looks like I'll be taking a big leap into the world of duet and RepRap firmware and I hope it'll soften the blow.
                                  appreciate the help!20210110_195329.jpg 20210110_211426.jpg 20210111_214253.jpg
                                  Thanks in advance! Pete from Root CNC
                                  • Haggan90undefined
                                    Haggan90 @RootCNC
                                    @RootCNC Hi,
                                    Sure I can share how to set it up.
                                    But I'm having a hard time understanding how you route your belts to make it a Haq-XY kinematics?
                                    RootCNCundefined 1 Reply Last reply Reply Quote 0
                                    • RootCNCundefined
                                      RootCNC @Haggan90
                                      @Haggan90
                                      Ah sorry about that - Please see this photo.
                                      I currently have two motors driving the Y axis - these shall be configured in a series configuration.
                                      then two independent carriages driven from independent steppers.
                                      Does that help?
                                      Thanks 🙂
                                      • Haggan90undefined
                                        Haggan90 @RootCNC
                                        @RootCNC Aha I see!
                                        I routed my 2 X belts on the same route but at different heights instead 😃
                                        And I used one stepper for the Y axis but with a rod connecting both sides of the Y axis.
                                        But the kinematics are exactly the same.
                                        Btw, are you stepper mounted in the bottom with rods going to the top?
                                        • RootCNCundefined
                                          RootCNC @Haggan90
                                          @Haggan90
                                          Yeah, to keep its low profile and symmetrical I went this way with the belts.
                                          I plan in the future to try a heated chamber, so keeping the motors below the 6mm plate seemed a good idea.
                                          I just purchased my Duet 3 and LCD, hopefully it'll turn up soon and then we can get this printer moving!
                                          Was the setup difficult?
                                          • MaxGyverundefined
                                            MaxGyver @Haggan90
                                            @Haggan90 said in Haq XY:
                                            I am still having this bug, even after updating from the latest beta to 3.2 stable.
                                            When I home one axis, the other two lose their position. Although I think the correct axis are moving when they are homing.
                                            Visionaryundefined dc42undefined 2 Replies Last reply Reply Quote 0
