    Home Z-Axis Twice
    1.9k
    • RobinFaureciaundefined
      RobinFaurecia
      @dc42 we will change M574 command!
      Our bed is moving and the gantry is fixed in z (only moving x/y).
        dc42 administrators @RobinFaurecia
        @robinfaurecia said in Home Z-Axis Twice:
        So you trying to home to maximum Z, i.e. bed at the bottom - correct?
          RobinFaurecia
          @dc42 exactly, that´s right!
          dc42undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            So remove the G92 command from your Z homing sequence, and the M208 Z limit will define the position when the homing switch is triggered.
            • fcwiltundefined
              fcwilt @RobinFaurecia
              Why are you wishing to home at Z max (bed at bottom)?
                RobinFaurecia
                @fcwilt
                Because we thought that it is not possible to print the first layer while the endstop is triggered.
                Now we try to home Z at Z max. If this makes to much problems we want to change the endstop position to Z min.
                • fcwiltundefined
                  @fcwilt
                  Go ahead and home to Z min - it will work fine and save time.
                    RobinFaurecia
                    Now we can home the Z Axis twice thats good!
                    But everytime we home Z Axis (doesn´t matter if at Z max oder Z min) we have a difference of 0,2 to 0,5 mm between nozzle and bed. Maybe the difference is caused by hitting the endstop a little bit different every time we home the Z-Axis. Do you have any idea how we can fix this problem?
                      Have you tried reducing the speed of the second homing move, to see if that gives you a more reproducible result?
                        RobinFaurecia
                        @dc42 yes we had already ...second hit is really slowmo but it doesn't help.
                        • fcwiltundefined
                          I've never encountered that. I use micro switches with no arm on them and they work fine.
                          What sort of endstop are you using? Micro switch? Beam Break? Hall Effect Device?
                            RobinFaurecia
                            We are using mechanic switches with a push bar.
                            I've ordered a bem break now to try if its working better.
                            @fcwilt
                              If you have multiple Z motors, and you are measuring nozzle height at bed centre but the Z microswitch is at the side of the bed, perhaps your Z motors are getting out of sync and the bed is tilting?
                              • fcwiltundefined
                                "Push bar" - you mean the arm attached to the micro switch that presses on the actuator button?
                                Micro switches usually have more than enough accuracy and repeatability for use as end stops.
                                I suppose it might be possible that some brands of micro switches are not suitable but I have never encountered any.
                                "Beam Break" devices can work but they may not yield the crisp on/off action desired.
                                  RobinFaurecia
                                  @dc42 we only use one motor for Z-axis.
                                  @fcwilt yes, the ones with the arm attached to the micro switch.
                                  I hope the beam brake will work... it should be compatible.
