    Reserve IP address
    Duet Web Control
    • Edumaundefined
      Eduma
      If the DuetWifi is in WAP mode is there a way to reserve IP addresses based on a devices mac address. I would like to add a camera, but I am unable to set a static IP address on the web cam.
        That's not currently supported. Is there a way to configure your webcam to use a static IP address?
        • Korbohundefined
          Korboh
          You could use a software like Yawcam to get a static IP adress for your webcam (you can even choose a password to protect it). The software gives you 2 address (1 for a refreshing jpeg and 1 for a live feed of your webcam). That's what I use and I can check my print from anywhere, with the WebPanel or directly on a given webpage by the software.
          • Edumaundefined
            Eduma
            Unfortunately the wyze cam does not allow a static IP. I was looking at some third party firmware for the wyze cam but no luck.
            I will look into the Yawcam software.
