Layer shift in Y Axis only.
    Karim
    Hey guys trying to figure out this, I print a benchy in the Y axis and it has layer shift towards the top as you can see in the photo. Same setting no layer shift in the X Axis. The Y Axis Nema 17 is working @ 85% of total Amps.
    https://www.filastruder.com/collections/electronics/products/high-torque-axis-motor
    M350 X16 Y16 Z16 U16 E16:16 I1 ; Configure microstepping with interpolation
    M92 X160 Y160 Z1600 U160 E512.96:512.96 ; Set steps per mm
    M566 X480 Y480 Z24 U480 E300:300 ; Set maximum instantaneous speed changes (mm/min)
    M203 X9000 Y9000 Z360 U9000 E1500:1500 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z100 U1000 E5000:5000 ; Set accelerations (mm/s^2)
    M906 X950 Y1300 Z950 U950 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    Same setting as above, Layer shift in Y axis.
    Same setting as above, but no layer shift in X Axis.
    I just increase all the value, Now I don't have layer shift in Y Axis, but the printer is very jerks, you can also hear the noise it produces. I don't want to use it like this.
    M566 X1000 Y1000 Z60 U1000 E10000:10000 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000 Y6000 Z360 U6000 E1500:1500 ; Set maximum speeds (mm/min)
    M201 X3000 Y3000 Z150 U3000 E8000:8000 ; Set accelerations (mm/s^2)
    M906 X1200 Y1428 Z1130.5 U1200 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
    This was printed in the Y Axis with setting above I cannot see any layer shift.
    undefined 1 Reply Last reply 31 Jan 2019, 14:02 Reply Quote 0
      deckingman @Karim
      @karim The most common cause of layer shifts like that is something mechanical. Quite often, if the printer isn't dialled in quite right, then a blob forms on the part, the hot end collides with that blob, and something moves. If you use a print surface help in place by clips, that can move. Or a belt might jump on a pulley. Or it might not be caused by a blob forming. Maybe a pulley is loose on a shaft somewhere?
      The fact that it shifted once, then the rest of the print continued tends to rule out most things related to configuration settings.
        Karim
        That's the first things I did, the two Y axis belts are tension ok, pulley are tight on shaft. The only thing I did not check is the linear rails on both sides. I am using buildtak flex plate, Z axis only move up and down. I made the printer faster and it did not skip (layer shift) . So I am thinking it has to do with my setting. It too jerky now, but setting does not produce layer shift.
          Which Duet are you using? There are two causes of layer shift on the Duet Maestro that don't apply to the Duet WiFi/Ethernet.
            Karim
            Duet wifi
            1 out of 5
